Front hitch question
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Aug 3, 2021.
  1. Aug 3, 2021 at 6:34 PM
    eagleguy
    eagleguy [OP] New Member
    Have any of you guys ever installed a hitch on your 2021 Tundra? I had one on my 99 Tahoe back in the day and found it very useful.
  2. Aug 3, 2021 at 6:38 PM
    biebs96
    PA
  3. Aug 3, 2021 at 6:41 PM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Comes in handy when your pulling a camper!
    NewImprovedRon likes this.
  4. Aug 3, 2021 at 6:59 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Wish there was one that was not so low that would come out of where license plat is,
  5. Aug 4, 2021 at 8:39 AM
    2mchfun
    Got a drawtite mounted under the Ranchhand bumper, not bad with a little liftIMG_20210429_072033.jpg
    Luckydog and panicman like this.
  6. Aug 4, 2021 at 8:42 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I just put one on a 2014. Love it. Takes 20 min and under $150
  7. Aug 5, 2021 at 5:19 PM
    eagleguy
    Do all the front hitches require modification to the front skid plate for oil change.
  8. Aug 5, 2021 at 5:26 PM
    I'm not sure but I think that refers to the stock skid plate only. They bolt on where the tow hooks are mounted, so I'm thinking that you can't remove the skid plate once the hitch is installed? I have the RCI on mine but interested in a front hitch as well.
  9. Aug 5, 2021 at 5:51 PM
    George the tow hooks are not mounted on the same bolts as the factory skid plate.
  10. Aug 5, 2021 at 5:58 PM
    Right I understand that. I'm curious as to why they say to cut a hole in the factory skid for oil changes. Why not just remove the skid plate? I have the RCI skid so I would assume that the hitch will still fit.
  11. Aug 5, 2021 at 6:02 PM
    Guess the bar is a tight fit that probably lays onto of the plate and you won't be able to on wedge it.:notsure:
    Tundra2010&60 likes this.
  12. Aug 5, 2021 at 6:03 PM
    That's what I'm wondering myself. I'll have to crawl under mine and poke around and see where the hooks are in relation to the plate.
  13. Aug 5, 2021 at 6:24 PM
    biebs96
    PA
    When I had a front hitch installed on my 2010 it was removed, along with the tow hooks, for every oil change.
    The cross member of the hitch blocked the front skid plate bolts.
    The fit in the front was so tight that after two oil changes, I never installed any of the front bolts, left the hitch on full time and ran that way for 4-ish more years.
    Tundra234 likes this.
  14. Aug 5, 2021 at 8:37 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    gosolo likes this.
  15. Aug 5, 2021 at 11:52 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    ZappBrannigan likes this.
  16. Aug 6, 2021 at 7:13 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    It's free for whomever wants to get it. Just paying it forward.
    What does not work for me may work for someone else. So essentially one man's trash is another ones treasure.
  17. Aug 6, 2021 at 7:17 AM
    2mchfun
    It's not fun to install the front hitch and keep the truck transport anchor points. In my case, I have had to hold up the Ranchhand bumper bracket, hitch, and the anchor loop all at the same time while starting the bolts with the other hand. Those three items are heavy as hell especially considering the hitch mount makes it very difficult to align the anchor loops in order to thread the bolts. You will need plenty of patience if doing the install alone. It can be done, just beware not a fifteen minute install.
  18. Aug 6, 2021 at 9:06 AM
    panicman
    Eric
    Whoa… thin skin.
    sorry for any offense.
  19. Aug 6, 2021 at 9:09 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    No man, not the intent, after reading it myself I sound like a total dick (now I know why my wife is always pissed at me), but I was being sarcastic. Should have thrown one of these in there...:);):boink:
    panicman[QUOTED] likes this.
  20. Aug 7, 2021 at 6:23 PM
    eagleguy
    Thanks for the input.
  21. Aug 10, 2021 at 6:49 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I have one that I used for mounting my snow plow. It sits up high enough and is not the lowest point on the front of the truck. I simply cut a hole in my skid plate for oil changes and use a plate the screw over the opening. I spent some time on it and it looks like it came from the factory the way I did it.
  22. Aug 11, 2021 at 5:39 PM
    eagleguy
    Do you have photos of the cutout? Also what what year truck? Draw Tite part number.Thanks.
  23. Aug 11, 2021 at 7:36 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would take some for you but I dont have access to my truck right now. Do a google search on measurements on where to cut the pan. You can use a plumb bob on the inside to make sure your centered under the filter housing. Cut the square out leaving rounded corners. I then drilled four holes on each corner and used nutserts. Fashioned a covering plate to cover.
    My truck is a 2020 but they are all the same. I used the Drawtite but the Curts was almost identical. I bought it from Etrailer. If you zoom in on the picture you can see the part number on the sticker.
  24. Aug 16, 2021 at 6:10 PM
    eagleguy
    Is one brand of front hitch a better fit than others?
  25. Aug 17, 2021 at 5:41 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I asked etrailer that question when I bought mine. They had said both the Curt and Drawtite hitch where almost identical with the Drawtite having a slightly longer receiver. Buy the one that is the best price.
  26. Aug 17, 2021 at 9:31 AM
    eagleguy
    Sounds like a plan. Prices are pretty much the same.
  27. Aug 17, 2021 at 10:04 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When I bought mine a couple of years ago I chose the Drawtite because it was a little longer on the receiver end and I was thinking it would be easier to install the pin.
    2mchfun likes this.
  28. Aug 17, 2021 at 10:16 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Exactly my reasoning also.
    2mchfun and Ruggybuggy[QUOTED] like this.
  29. Aug 17, 2021 at 10:28 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Oh, BTW...the dealer absolutely loves my front hitch. They make sure to mention on every oil change paperwork, that they had to remove it in order to get the skid plate off.
  30. Aug 17, 2021 at 10:37 AM
    2mchfun
    The skid on my truck has some tabs that slip and lock in some slots at the front above the hitch, use an open end wrench on those two bolts and it is a piece of cake to change the oil. No lower apron to deal with though, so I guess you all are having issues with those three screws that hold up the plastic lower bumper airdam or apron. Thanks Ranchhand for eliminating that garbage.
