Front End Popping 2000 Tundra 4x4
Discussion in 'Suspension' started by Welder6131, Mar 28, 2017.
  1. Mar 28, 2017 at 1:54 PM
    Welder6131
    Welder6131 [OP] New Member
    Josh
    2000 v8 Tundra limited
    Hello all!
    Just bought my dads 2000 Tundra Limited 130,000 miles and I have been going through all the typical PM stuff on the truck. I noticed I will hear a pop sound when the truck flexes or moves a certain way. My initial thought was a ball joint as the sound is coming from the front end. Could anyone give me a couple of the usual suspects for me to check. I had a 4 runner that did the same thing but I sold it before ever repairing it.
    Thanks,
    Josh
  2. Mar 28, 2017 at 2:11 PM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Ball joints for sure. Do the first gens have a stabilizer bar up front too? May be another point of contact that is moving a little.
  3. Mar 28, 2017 at 2:43 PM
    Welder6131
    Josh
    Yup they have stabilizer bar as well. Bushings were replaced about 3 years ago on stabilizer bar and ends too.
    Any need for alignment after replacing ball joints?
  4. Sep 12, 2017 at 11:39 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    You shouldnt need to do an alignment after replacing lower ball joints.
  5. Sep 12, 2017 at 12:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check that the alignment cam bolts on the lower control arm are tight, very tight
