Front end Pop
Discussion in '2.5 Gen Tundras (2014-2021)' started by kwebre, Dec 24, 2020.
  1. Dec 24, 2020 at 2:46 PM
    kwebre
    kwebre [OP] New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    Need help. Popping sound coming from from left side when I hit a bump and/or make a left turn.
  2. Dec 24, 2020 at 2:47 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Any modifications on the truck?
  3. Dec 24, 2020 at 3:55 PM
    kwebre
    2020 Blck Tundra
    4” procomp lift.
  4. Dec 24, 2020 at 4:57 PM
    SouthWestGA
    SouthWestGA New Member
    Did you have the lift installed recently? Was an alignment performed?
  5. Dec 24, 2020 at 5:21 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    We need some more information. Has anything changed? Can you repeat it while parked - moving the truck up and down? Check sway bar links, coilover bolts, LCA bolts. Make sure you don’t have anything loose. Post a video of the sound.
  6. Dec 24, 2020 at 6:34 PM
    kwebre
    2020 Blck Tundra
    Lift was installed when I purchased the truck. I have 10k miles on the truck and the sound started a couple weeks ago. It doesn’t happen when parked.
  7. Dec 24, 2020 at 8:03 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Either something is loose or something needs to be replaced...have a technician diagnose and repair if you can’t do that yourself.
  8. Dec 25, 2020 at 7:19 AM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    Put a wrench on all the suspension components that were installed, and check for torque. It’s either a loose bolt or possibly a bushing going bad on a component.
