Front end noise
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Jan 1, 2023.
  1. Jan 1, 2023 at 9:51 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Have noticed a noise from the front of the truck. Noticeable when turning at lower speeds (parking lot , driveway, etc). Doesn't make the noise going straight
    best way I can describe it is it sounds almost like a spring under tension. Seems like it is a rotational noise with the wheel or axle? I am going to grease my control arm bushings but wanted to see if anyone else has had this issue or any ideas where to look
  2. Jan 2, 2023 at 6:23 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    I had a noise similar to what you described - It was the ball joint on my upper control arm that gave out and had to be replaced.
    Jeffro22[OP] likes this.
  3. Jan 2, 2023 at 8:11 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Do you have a front skid?
  4. Jan 3, 2023 at 8:10 AM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    That'll be a ball joint. Is it a metallic "pop" sound like something is binding and then breaking loose?
  5. Jan 7, 2023 at 5:13 AM
    Jeffro22
    yes
  6. Jan 7, 2023 at 5:15 AM
    Jeffro22
    I have aftermarket UCA with uniballs
    lca are original
    doesn’t sound like a pop. More like a tension spring winding up
