Front end noise at low speed
Discussion in '2nd Gen Tundras (2007-2013)' started by snarf68, Mar 26, 2021.
  1. Mar 26, 2021 at 1:31 PM
    snarf68
    snarf68 [OP] New Member
    Hello all,
    2008 Tundra with 125,000 miles. Have a very light grinding sound from the front end at low speed. I can hear it slightly at speeds under 30. 25 seems to be the peak. Anything above 30 and it disappears. There is also just a bit of feedback thru the steering wheel at 25 mph too.
    Everything works, no leaks anywhere, 4wd engage/disengage does not affect the noise/grinding.
    Any help from you all will be appreciated. Thanks.
  2. Mar 26, 2021 at 2:50 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would check brakes, see if they are dragging or caliper hung up a bit and check the hubs/wheel bearings, they can make that kind of noise.
