Front end - feels loose?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RailroadAG93, Sep 17, 2015.
  1. Sep 17, 2015 at 7:25 PM
    RailroadAG93
    RailroadAG93 [OP] New Member
    Craig
    2014 Tundra Crewmax Platinum
    305.55.20 Toyo AT2's 3.0" Leveling kit Rigid Grill & LED's
    Not sure if this makes sense, but sometimes when I hit a bump in the road it feels like the front end isn't real tight? I came out of an F150 and never felt this before. It was always super tight no matter what kind of bump I hit. I have a leveling kit on there and not sure if this may be the problem. I bought it used (15k miles) and not sure if the kit might not be installed correctly.
    Any suggestions?
  2. Sep 17, 2015 at 7:26 PM
    RailroadAG93
    Craig
    One more thing, I have LT 305 55 20's on there and being a 10 ply tire that this may be the issue.
  3. Sep 17, 2015 at 8:00 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Probably the lift and heavy tires. Know anyone else with a lifted tundra you could ride with to compare?
  4. Sep 17, 2015 at 10:03 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Possibly bump steer. When was the last time you got your alignment done?
  5. Sep 18, 2015 at 4:28 AM
    RailroadAG93
    Craig
    Had my alignment done right after I bought it. There was a slight tilt to the right in the steering wheel so I had the tires rotated and balanced and am alignment done.
  6. Sep 18, 2015 at 4:30 AM
    RailroadAG93
    Craig
    Yea TruckyTruck, I rode in my buddies 15 crewmax 4x4 but I didn't drive it. His was definitely much much smoother.
