Front end "clunk" noise on 2015 Tundra LE crew cab - ABS brakes pressurizing?
Discussion in 'General Tundra Discussion' started by millertundra78748, Feb 23, 2016.
  1. Feb 23, 2016 at 3:05 PM
    millertundra78748
    millertundra78748 [OP] Livin' the moon time.
    Austin Texas
    2015 Tundra Crewcab limited 4x4 MAGNETIC GRAY METALLIC
    Anyone hear a short and low "clunk" noise after about 20 seconds of driving right when you turn on and warm up and drive down the street? Within 15-20 seconds hear this low clunk. Looked on other forums and others are saying that Toyota is saying it's abs pressurizing and totally normal. Anyone else have this happening? Doesn't appear to do doing anything different or bad. Just strange. Sound is coming from left bottom of truck or at least it sounds like it.
    from another board
    "I took the vehicle to the dealer and a mechanic looked at it. I was told that this is completely normal and that every Tundra makes this clunk noise. He said that the ABS is getting pressurized. He explained that once the ABS has been pressurized once, it does not reset until the vehicle has be restarted. Which makes sense because once I hear the noise, I never hear it again unless I turn the truck off. "
  2. Feb 23, 2016 at 3:34 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    My 2015 does it, no big deal its the ABS system doing a self check from what I was told
  3. Feb 23, 2016 at 5:43 PM
    Normal, but mine doesn't do it. :notsure:
  4. Feb 24, 2016 at 9:51 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Mine does. I have seen the other thread too but just forgot to post in it. Happens right about 13-15 mph. If its normal i wont worry. But it is kinda annoying.
  5. Feb 24, 2016 at 9:58 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
