Front drivers side rattle
Discussion in '1st Gen Tundras (2000-2006)' started by Nmmk6, Sep 23, 2018.
  1. Sep 23, 2018 at 5:27 PM
    Nmmk6
    Nmmk6 [OP] New Member
    Neil
    03 TRD
    5100s level, 285/75/16 Ko2.
    03 tundra front end rattle noticable at lower speeds coming only from the driver's side. New tires, wheel bearings, lower control arms, shocks, lower & upper ball joints, steering rack bushings, swaybar bushings. About to give up.
  2. Sep 23, 2018 at 6:35 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rattle like metal to metal contact? Not on the interior I assume.
  3. Sep 23, 2018 at 6:36 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    You sure you don't have a dog leash hanging off the rear bumper Clark?
    Darkness likes this.
  4. Sep 23, 2018 at 7:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Poor little guy... probably kept up for a mile or two...
    :oops:
    BubbaW, aRabidLunatic and Sas like this.
  5. Sep 24, 2018 at 4:22 AM
    Nmmk6
    Neil
    03 TRD
    Hahaha, it's not on the interior. I've looked through all sorts of forums and even replaced the steering rack bushings and sway bar bushings. It literally sounds like my suspension is about to fall off but I know everything is new and replaced.
  6. Sep 24, 2018 at 6:13 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is your truck lifted at all?
  7. Sep 24, 2018 at 6:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    When you did the shocks did you get new upper mounts for the springs?
    Also how do the control arm bushing look, at 15 years they're probably done for.
  8. Sep 24, 2018 at 7:16 AM
    Nmmk6
    Neil
    03 TRD
    Yes, bilstein 5100 level shocks that's it. Nothing else. The shock pads has not been replaced.
  9. Sep 24, 2018 at 7:21 AM
    Nmmk6
    Neil
    03 TRD
    The lower control arms had been replaced.tie rods, upper ball joints, steering rack bushings, sway bar bushings.
  10. Sep 24, 2018 at 8:20 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I look hard at the upper spring mounts and the upper control arm bushings since it sounds like you've replaced everything else.
    FrenchToasty likes this.
  11. Sep 24, 2018 at 8:58 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I have a 2000 limited TRD access cab with over 300,00 miles and it does the same thing! I have done the same thing you have but, I didn't replace the spring mounts.my front end pops and makes weird noises also for the last 3 yrs. I realize what the problem is, I just haven't taken the time to repair it. I have even replaced the rack and pinion!
  12. Sep 24, 2018 at 9:10 AM
    Nmmk6
    Neil
    03 TRD
    It's VERY frustrating! I will be replacing both front strut pads and follow up.
  13. Sep 24, 2018 at 9:52 AM
    Nmmk6
    Neil
    03 TRD
    Yes. Sounds like a thud for when you hit a dip when the spring dips for a bump and the rattle noise happens while going over very rough surfaces. Like I said, a thud when the front spring decompress rapidly and rattle noise while going over rough surfaces.
  14. Sep 24, 2018 at 10:59 AM
    tenntundra
    Walter
    Tennessee
    Good,let me know if that takes care of the problem.
  15. Sep 24, 2018 at 12:31 PM
    Nmmk6
    Neil
    03 TRD
    Be aware if you try to tackle this job yourself. So, I go online on toyota parts and I thought I had all the parts required. Then I go to the parts dept at the dealer and looked at their computer, it breaks it down further! So my advice is to fork over the cash to let the dealer do the bearing replacements. Only because, my original plan was to pull the axles and let a machine shop remove and install all the required parts but after realizing more and more need to be replaced, I leaned towards letting the dealer to do the job right. Just for a peace of mind.
  16. Sep 24, 2018 at 2:28 PM
    Nmmk6
    Neil
    03 TRD
    The top two on this parts receipt are related to this topic, ordered and on the way.The rest, both rear wheel bearing replacement by utilizing toyota dealer parts department. The parts manager gave me a huge discount.
  17. Sep 24, 2018 at 3:47 PM
    Nmmk6
    Neil
    03 TRD
    Another unrelated source of rattle/ annoyance is check the "V8 and the front grill em emblem they rattle too.
  18. Sep 30, 2018 at 7:00 PM
    Nmmk6
    Neil
    03 TRD
    It definitely fixed the problem. Thank god.
  19. Oct 17, 2018 at 11:41 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Are they just held on with double sided tape or what?
  20. Oct 17, 2018 at 12:54 PM
    Nmmk6
    Neil
    03 TRD
    Its clipped on to the grill. Now you can just tape it to stop it rattling.
  21. Oct 17, 2018 at 9:43 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Been considering a mesh grill but would like to retain the v8 grill badge. Was hoping it had a screw or two.
  22. Oct 18, 2018 at 4:19 AM
    Professional Hand Model
    Hand Protectors
    As an alternative, you can by one of the V8 double sided stickers from Toyota. They run about $30.
    Its not the same as the clip on grill type as discussed, but it will do the job.
    Acatlin96 likes this.
  23. Nov 4, 2018 at 10:14 AM
    SeanO86
    SeanO86 Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    So, what was your issue exactly? You said you realize what the problem is but never mentioned exactly what that was.
    2018 Tundra SR5 with Fox 3.0 IFP coilovers with 3” lift and SPC UCAs. I have a bad thud/clunk coming from my front driver side when hitting potholes. I’ve had my shop check torque settings/ tightened all my UCA bolts and greased up the UCA ball joint. We can’t figure out what this noise is coming from. Sucks cause the suspension was awesome until this. Now I hear and feel this thud/clunk every damn time I hit a pothole or small bump in the road. Frustrating.
    NomadicFrog and lj1 like this.
  24. Mar 6, 2019 at 11:13 AM
    lj1
    lj1 New Member
    Jake
    White 2010 TRD Rock Warrior Crewmax
    Iron Cross Steel bumper with push bar, Air Raid cold air intake, trd dual exhaust, 33'' k02 w/ 17'' rock warrior rims
    I'm having the same issue with my 2010 trd rw. Front drivers driver's side loud thud Everytime I go over a bump. I'm just gonna bite the bullet and take it to the dealership
  25. Sep 15, 2019 at 12:02 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    2004 4x4 V8 RCLB 2006 4x4 V8 RCLB
    My stock 4x4 2006 Tundra has been rattling on bumpy roads for the last 70K miles....ever since it had 120K miles on it. First I replaced the front struts, then axle bushing on front diff, then both lower control arms and bushings. I replaced both front axles. I checked the ball joints at least five times, even with the lower control arms off, but never have been able to detect any wear in any of them. I did get the ball joint recall done at about 30K miles. I guess ball joint failures mainly happen to lifted Tundras. My hearing is poor, but it sounds like the right front. I even tightened up the camper shell bolts in case it was bouncing against the bed.
    If I jack it up and get under it, I can grab the axles and shake them up and down and they will rattle, if I shake them in and out they rattle a different tune.
    I don't know the solution since I replaced both axles and the diff bushing and that didn't help.
  26. Nov 26, 2019 at 1:35 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Yeah, since the problem sounds exactly like mine, it would be great to know what the actual final thank god solution is.
    Best I can figure, your solution was the top two items on that parts quote? One was the stabilizer bar bushing, which I've already replaced, which leaves the other one:
    Upper Mount - Toyota (48609-0C021)
    If that was indeed what fixed the problem, what exactly in that part goes bad? I'm trying to remember when I installed the Bilstein 5100s what's in there - isn't it just a metal plate, then you put a new rubber strut mate in there for cushion? Or is there something else that goes bad that necessitates a new Upper Mount part for $70-$100+?
  27. Nov 26, 2019 at 2:42 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'll take a WAG and say it was the spring mounts/strut pads.
  28. Nov 26, 2019 at 3:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve had a strange squeak from somewhere, I’ve been juicing everything I could think of with triflo to no avail. It’s usually backing out of my uneven driveway or on the trail the other weekend, the whole effing time, sounded like a broken violin. This weekend getting out with momma bear, I shifted my weight just right and about screamed in joy(I haven’t been able to reproduce the sound!!) so I made her go to the rear; said not here, she made her way to the front passenger wheel well.......I wonder if the upper mount is the Bain of my noises!!?
  29. Nov 27, 2019 at 7:33 AM
    tenntundra
    Walter
    Tennessee
    Every month or two , I spray my strut caps and my sway bar bushings with white lithium grease and it seems to stop the popping and squeezing. It's a cheap fix that might take 5 minutes. JMO!
  30. Jun 2, 2020 at 4:42 AM
    McConnellHand
    McConnellHand New Member
    Lane
    Homemade Sequoia TRD
    intake, exhaust, leveled, tires, homemade rack, light bar.
    I have been dealing with the same issue it sounds like for the past month now. 2004 Sequoia 4x4. After going through everything on my front end it seemed like. I think I narrowed it down to the culprit. The upper mount for the springs. Ignored mostly. But when I got underneath the rig I completely compressed the suspension on my jack and tightened the top nut on the spring and shock assembly, and the noise was almost completely gone. Picked it back up, replaced the upper mount. Tightened everything back up and the noise is gone. Thank god.
    NomadicFrog likes this.
