Front diff torque specs
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2-4-5 trioxin, Aug 23, 2023.
  1. Aug 23, 2023 at 3:56 PM
    2-4-5 trioxin
    2-4-5 trioxin [OP] New Member
    2020 Tundra Limited
    Just finished changing the fluids in my front diff and transfer case. I just want to double check to see if the front diff torque spec is 29ft/lbs for both the drain and fill plug.
    I’ve tighted both to 29ft/lbs but just read somewhere else the fill is supposed to be 29 ft/lbs and the drain is supposed to be 48 ft/lbs.
    Please let me know if I need to tighten the drain plug more.
  2. Aug 23, 2023 at 4:15 PM
    centex
    centex New Member
    I tighten it gutentight and it works.
  3. Aug 23, 2023 at 6:01 PM
    2-4-5 trioxin
    2020 Tundra Limited
