Front Diff and Trans breather location?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra44, May 10, 2014.
  1. May 10, 2014 at 7:18 PM
    Tundra44
    Tundra44 [OP] New Member
    2007 SR5 CrewMax
    King shocks front and rear, Spider trax spacers on Rock Warrior rims, Demello Off-road front bumper with Tuff Stuff 12.5 winch.
    I relocated the rear diff breather and was wondering if anyone knows where our front diff and Trans breathers are located. In the FJ they are in the engine bay and pretty easy to locate. The 1st Gen. Tundra vented both in the engine bay as well. I can't find 'em in my truck.
  2. May 10, 2014 at 10:04 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I could have sworn they were also in the engine bay, but maybe im thinking of my tacoma. Ill have to take a look now.
  3. May 10, 2014 at 10:44 PM
    Tundra44
    2007 SR5 CrewMax
    They likely are, but they were not as obvious as they are on the FJ, so I didn't see them. I'll take a better look. In the mean time, if you find 'em, holler.
  4. May 11, 2014 at 6:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Found them! Under the brake booster.
  5. May 11, 2014 at 6:50 PM
    TruckyTruck
    Gary
    Good job dude
    Les7311 likes this.
  6. May 11, 2014 at 7:10 PM
    Tundra44
    2007 SR5 CrewMax
    Awesome! I'm going out to look right now. Thanks for looking and posting up.
  7. May 11, 2014 at 7:32 PM
    Nice work, Bry!
    Les7311 likes this.
  8. May 11, 2014 at 8:48 PM
    Tundra44
    2007 SR5 CrewMax
    They sure weren't very obvious. Thanks again. I think they're high enough that I don't have to mod them like I did with the rear.
  9. May 11, 2014 at 9:38 PM
    csuviper
    Broomfield, CO
    No you should be fine. There are much more important things to worry about if you go that deep in water, like the engine. Diff is cheep in comparison to a new engine :)
  10. May 11, 2014 at 10:16 PM
    Tundra44
    2007 SR5 CrewMax
    I *try not to go in water deeper than the frame. The rear diff breather wasn't well placed for that.
  11. May 12, 2014 at 7:32 AM
    csuviper
    Broomfield, CO
    Good idea. Soaking interior wouldn't be good either. Agree on the rear breather location being on the axle however lets discuss how water would get in.
    From what I know, the axle would need to be hot enough that when it hits the cold water it will cool quickly pulling air or water into the axle to make up that space difference. How hot does the axle need to be? How quickly does it need to cool? How much volume is displaced? Does a little water really cause any problems if changing gear oil on a reg basis?
  12. May 12, 2014 at 7:57 PM
    Tundra44
    2007 SR5 CrewMax
    From everything I've read and discussed with some buddies, you're correct with how the water would get in. How much would get in? I don't honestly know. But it would seem anything other than condensation would be bad.
    How frequently do you change your diff oil or transfer case oil? I use Mobil 1 synthetic gear oil and I go about 30k between changes. Honestly, the transfer case always looks clean. The rear gets pretty dirty and the front not so much. My previous two Toyota 4x4s have always had really clean xfer case oil too. Not sure why but it seems to be a Toyota trait.
  13. May 14, 2018 at 12:32 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I know this is an old post, but maybe someone can answer a question...
    Yeah, the front diff breather seems to be high up in the engine bay, but is it a ONE WAY breather? If it is like the rear where air can only get out, not in, then shouldn't the cab be removed and a small filter put on the end?
    Tundra18overland and acmesupply like this.
  14. Dec 26, 2018 at 1:36 PM
    JayPee
    JayPee New Member
    Chandler, Az or San Gabriel, Ca
    2017 Toyota Tundra Sr5 TRD 4x4
    in my dreams
    the rear diff I believe is a 2 way breather.. how it works is if the rear is hot enough, hot air gets pushed up and out and if that happens while youre sitting in the water the blow off will cause a suction effect and that's how the water gets in. ive had one of those little diff breather balloon where its basically a one way balloon and it expanded significantly pretty big.
  15. Dec 26, 2018 at 3:07 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    They are one-way in a sense that full hot to cold water will cause a immediate suction/vacuum that has to come from somewhere. Either through the seals and bearings or aftermarket two-way breathers.
    The OEM only allows out flow to keep water out. When changing diff fluid at normal temps you usually will notice a slight suction when you open the top or bottom .
    This applies to all diffs , transfer case and transmission.
  16. Dec 27, 2018 at 12:21 AM
    chasen
    chasen New Member
    Chasen
    very nice picture,show a location of diff and Trans breathers
  17. Sep 18, 2019 at 6:43 AM
    Fuzzytowel
    Fuzzytowel New Member
  18. Jan 12, 2020 at 5:16 PM
    MoShootin
    MoShootin New Member
    2003 Sequoia Limited
    Hi all! I'm new here.
    I have a 2003 Sequoia. I've been working in Wyoming for a couple weeks and the temperature is in the teens and 20's. When I got home I found a fair amount of oil on my garage floor. From what I can tell the oil seems to be coming from the breather hoses pictured in post #3. Since the hoses are next to each other I'm not sure which one the oil is coming out of.
    Background. I had front and rear differential and transfer case oil changed about 5 months ago (August). Afterwards there was minor dripping from the front axle area. The shop checked to make sure the drain plug was tight and they said the right side axle seal on the front end was leaking. I haven't had that fixed yet but very little oil appeared to leak. I don't use 4x4 often but I did use it in the snow a little over a week ago.
    Any idea what would cause that to happen?
    Thanks!
    Surf_spear_Mex likes this.
  19. Sep 12, 2020 at 10:39 AM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Sam
    Same boat but oil coming out of the smaller of the two lines, looks like brake fluid???
  20. Feb 9, 2022 at 8:02 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Sorry for reviving this old thread but isnt one of the breathers pretty low? (correct me if im wrong). The breathers in the engine bay are the transfer case and the front differential correct? What about the transmission breather? OP mentioned the FJ, which does have them high up in the engine bay as well for the transfer case and front diff, but the FJ (at least my 07) has a Transmission breather thats literally on top of the bell housing (pretty stupid design). Additionally, its one of those flimsy POS check valves. I didnt trust it one little bit so i routed the transmission breather way up high with the other ones.
    Does anyone know where the transmission breather is on the Tundras? Im gonna dive under my 2020 this coming week when i do all of my fluids and check things out.
    dongziye likes this.
  21. Apr 12, 2022 at 7:15 AM
    dongziye
    dongziye New Member
    I was also wondering the same question. Where are the transmission and transfer case breathers.
  22. Apr 12, 2022 at 7:22 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    I still don’t have an answer for the transmission breather. All the other ones are up high enough that i think you’d be fine unless you do some very deep crossings. Of course the rear is low but that’s a quick fix. Only transmission one remains a mystery.
  23. Jul 19, 2022 at 10:49 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    I just found it. Looks like maybe two breather hoses. Impossible to get to looks like unless you drop the trans. Tundra Trans.jpg
