Front Coilover overkill?
Discussion in 'Suspension' started by McCrapper, Dec 15, 2020.
  1. Dec 15, 2020 at 8:00 PM
    McCrapper
    McCrapper [OP] New Member
    Hello all.
    I've searched exhaustively for some answers on this idea and I didnt find anything so here it goes...
    Its a 2020 Tundra doublecab with front bumpers (216 net lbs added) rear replacement (90lbs) headache rack (150lbs +/- ?) and a cross tool box (100lbs) and otherwise completely stock after that. I have been mashing on this truck pretty hard, I can really feel the weight and frontend take the impact when Im doing 30-50 mph on rough washboards and rocky trails. Going up and down dips and having almost catching air a couple times I need to do something about the frontend slamming so hard. I only do this type of driving every few weeks for maybe 40-50 miles at a time but I'm not going to slow down my driving.
    Im thinking of throwing some 2.5'' Toytec coilovers with 700lb springs preset to 2" inches of height with some JBA off road UCAs to help with articulation and improve the strength. I dont believe the rear suspension is lacking much in my driving. Ill be leveled out and improve offroad capability. Ill eventually throw larger tires but only the 295/70/r18 options and I will add skid plates ASAP.
    Is this sufficient or is this overkill? Any downsides to this Idea?
    AccuTune Offroad likes this.
  2. Dec 15, 2020 at 8:49 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    2.5 coil overs with 700lb spring should be good, I have about 250 lbs between bumper, winch, and lights and 700lb springs and it does pretty good. also add in some durobump or wheelers bump stops to help with bottoming
    McCrapper[OP] and SC_TRD like this.
  3. Dec 15, 2020 at 9:31 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    I definitely don’t think it’s overkill, I run Fox 2.5s with 700lb coils and love the way it drives. I definitely don’t have as much weight as you in the front, so it definitely wouldn’t be too much. Also agreed with @TG705 throw some duro bumps on there in front too and it should really smooth things out.
  4. Dec 16, 2020 at 6:11 AM
    McCrapper
    Ahhh bump stops. Good idea. I talked to a guy at Toytec and he was very nice and informative but I could also tell he was judging me for not fooling with the rear end.
  5. Dec 16, 2020 at 6:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Toytec is good stuff, however with that heavy bumper and load you may want to look at OME suspension. They have 3 different coils available based on load and their suspension are tuff, will handle off roading with heavy loads, bumpers, etc. I have run a few of their suspensions and they are my favorite for heavy duty use, loaded trucks. I have run their "light" suspension on my 06 4runner for many years and it drives great and is a beast off road. It also really helped with towing, the stock suspension was a little spooky when loaded or towing.
    McCrapper[OP] and timdske like this.
  6. Dec 16, 2020 at 10:52 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    With the various weight you have added, combined with very frequent off-road driving, I would suggest looking into something better than a Toytec bolt on shock. I'm sure it will ride better, however it will still just have off the shelf valving for a stock truck.The springs are more toward holding the weight of you truck, not so much to do with smooth ride quality. If you plan to keep the truck for a long time, and want the best performance on and off-road, a custom tuned Fox or King setup would be the hot ticker IMO. Good investment for a nice truck. Plus they would be tunable & rebuildable vs just having to throw them away when they are toast.
  7. Dec 16, 2020 at 11:00 AM
    McCrapper
    Well Im open to suggestions for sure. You have a quote you can send me or somewhere to reference?
  8. Dec 16, 2020 at 11:10 AM
    AccuTune Offroad
    El Cajon, CA
    PM sent!
  9. Dec 16, 2020 at 11:23 AM
    BayRunner
    2017 Tundra Platinum
    I can attest to Accutune's custom tuning. My Kings ride great. Hit some rough washboards pretty hard today and they soaked them up.
    SC_TRD and AccuTune Offroad like this.
  10. Dec 24, 2020 at 12:23 PM
    BayRunner
    I can’t compare it since I sent mine to Accurune as soon as I received them. I can say that I like the tune very much. They’ve handled the washboards i’ve hit very well. BTW, the Kings I ordered apparently had older model pistons in them which had to be replaced by Accurune in order to be tuned.
