Front brake replacement question
Discussion in '3rd Gen Tundras (2022+)' started by Daedalus, May 26, 2025 at 12:26 PM.
  1. May 26, 2025 at 12:26 PM
    Daedalus
    Daedalus [OP] New Member
    This is probably a dumb question.
    replacing pads on the front calipers, do we need to keep the factory pad shims in when putting the new pads on?
    I’ve done multiple cars say yes they are required, others not
    My GTI did not require them on my stoptech BBK.
  2. May 26, 2025 at 12:51 PM
    JDAZ
    JDAZ New Member
    Are you using OEM pads? If so then yes. Some Aftermarkets have the shims built in.
  3. May 26, 2025 at 12:51 PM
    Daedalus
    Nope. Z36 power stop
  4. May 26, 2025 at 2:28 PM
    Jimhowell79
    Jimhowell79 New Member
    Yesterday
    Tundra
    My truck @ high speed braking would shimmy after 20000. Dealer cut rotors 5000 more it came back. Replaced rotors and brakes Still shimmies @ high speed braking. Thoughts?
  5. May 26, 2025 at 4:03 PM
    Daedalus
    Update**. Shims out. Pedal seems much firmer and linear.
