Front Brake Problem
Discussion in '1st Gen Tundras (2000-2006)' started by Que, Nov 19, 2021.
  1. Nov 19, 2021 at 6:38 AM
    Que
    Que [OP] New Member
    2006 Tindra
    I bought a 2006 DC 2wd. Really like it but found that after driving around a bit the front brakes would start applying resistance as in major rubbing. To the point of the truck would drag to a stop without any pressure applied to the pedal. Turned over to Toyota repair and after a couple weeks, front brakes replaced, master cylinder replaced and I think booster replaced; I got it back. Well less than 200 miles later its starting to happen again. I noticed that once the brakes start this up then there is very little pedal travel and its very touchy.
    any thoughts? thanks
  2. Nov 19, 2021 at 6:41 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    calipers replaced?
    Fluid level to high in rez can create a reverse action and activate brakes once fluid heats up
  3. Nov 19, 2021 at 6:56 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would bring it back and complain. They've replaced just about everything (I assume when you say front brakes you mean the calipers as well?) except the ABS module (if you have it).
    Maybe one of the replacement items is a faulty part like the caliper?
    Punk1974 likes this.
  4. Nov 19, 2021 at 7:03 AM
    shifty` Animals and insects don't do drugs
    And the lines, but I doubt that's the problem, and agree on it's interesting it happens after a period of driving, as if fluid heat buildup is related.
    I also agree on taking it back, if it's still happening, you just threw a bunch of parts and money at something that didn't fix the prob.
    I'd also recommend to double-confirm if that booster was really replaced, look at the work order to verify.
    Jack McCarthy and Punk1974 like this.
  5. Nov 19, 2021 at 7:35 AM
    Punk1974
    J.P.
    pics of reciept plz
  6. Nov 19, 2021 at 7:44 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Agreed. OP, you didn't mention the word calipers.
  7. Nov 19, 2021 at 9:52 AM
    Que
    Que [OP] New Member
    2006 Tindra
    So it appears the booster was not replaced. In discussion now that is the next step. I will update...
  8. Nov 19, 2021 at 9:54 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Could be an incorrectly adjusted booster/pedal.
    This would be because the piston is somewhat blocking the reservoir port. If it's not fully unblocked/disengaged it could prevent fluid from fully returning to the reservoir over multiple brake applications, which leads to the fronts dragging then eventually locking up.
    bmf4069 and shifty` like this.
  9. Nov 19, 2021 at 12:33 PM
    This is essentially what I was thinking, and why I pushed about the booster up there. Great minds think alike ;)
  10. Nov 20, 2021 at 6:29 AM
    Que
    Que [OP] New Member
    2006 Tindra
    Thanks for the responses gents. I will let ya know they outcome.
  11. Dec 15, 2021 at 4:57 AM
    Que
    Que [OP] New Member
    2006 Tindra
    well I've had it back now for a couple weeks and all sees well with the brakes. All those that said brake booster...... you were correct. now to chase down a vibration coming through as I am in motion.
  12. Dec 15, 2021 at 8:12 AM
    Looks like me and @assassin10000 win on this one.
    What speeds are the vibrations coming through at, and what condition (stopping, accellerating, turning, etc) causes it?
    Also, I see your truck is 2WD, can you tell us whether it's lifted or not, and if so, more details on that lift and whether you made any driveline adjustments after?
  13. Dec 15, 2021 at 8:31 AM
    Que
    Que [OP] New Member
    2006 Tindra
    not lifted. difficult to explain but its like if you had a circle but only part of the surface was rough. thats how it is driving, not a continuous vib but a continuous cycle of the vib. speed doesn't seem to effect the timing of the vib, just the intensity. seems more pronounced when slower speed.
  14. Dec 15, 2021 at 9:06 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Is it like a faint rhythmic "wuhb wuhb wuhb" that you only hear but don't necessarily feel? Typically only comes on after 35-40mph? Like you said, wheel speed doesn't affect the rhythmic "wuh wuh wuhb"?
  15. Dec 15, 2021 at 9:48 AM
    Que
    Que [OP] New Member
    2006 Tindra
    Ok so i just drove it on smooth road. Vib is there but slower speed not bad. Do about 35 to 60 its there for sure. Its a felt vib for sure. Not ever too strong/dangerous but there
