Front Brake Low pad warning tab
Discussion in '2nd Gen Tundras (2007-2013)' started by Basementmechanic, Sep 13, 2019.
  1. Sep 13, 2019 at 7:58 PM
    Basementmechanic
    Basementmechanic [OP] New Member
    2012 2wd Tundra
    I am in the process of replacing front pads but didn’t notice which side inboard or outboard gets the squeal tab. Does it matter? Also what is the min rotor thickness? Both rotors are 32 mm now. Thanks in advance
  2. Sep 13, 2019 at 9:57 PM
    Welcome to the site.
    The pad with the tab goes on the inside.
    The rotor tolerances should be stamped on the rotor.
    NewImprovedRon likes this.
  3. Sep 14, 2019 at 5:20 AM
    Basementmechanic
    2012 2wd Tundra
    That would be too easy. Nothing is stamped on the rotors. Thanks, maybe parts store guy can look it up.
  4. Sep 14, 2019 at 5:46 AM
    Nothing on the hub? I’m betting it’s there (was), but minimum thickness is 29mm.
    Personally, I just replace rotors with pads every time, maybe I’ll pad slap once if rotors look/mic in spec.
  5. Sep 14, 2019 at 6:25 AM
    Basementmechanic
    2012 2wd Tundra
    I bought the truck 2 years ago, don’t have any history on the brakes. Odd with no stamp you are correct. Thanks for the info.
    ColoradoTJ likes this.
