Front Brake Caliper leaking
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Oct 4, 2021.
  1. Oct 4, 2021 at 12:35 PM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Noticed my truck has started to pull to the left when braking. I recently replaced the front calipers. Upon closer inspection I see the passenger side caliper has fluid all over it and is leaking.
    What's my best option here? doesn't appear to be leaking form bleeder or line so guessing the leak is around 1 (or all) of the pistons?
    I saved my original calipers with plans to rebuild them anyway but had hope to get by for a little while with these remans. Probably don't even have 6K miles on these calipers
  2. Oct 4, 2021 at 12:42 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    At $70 dollars for a replacement caliper, I don't think that a rebuild is worth it.
    Danny3737 likes this.
  3. Oct 4, 2021 at 12:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are the calipers still under warranty?
  4. Oct 4, 2021 at 12:49 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The reman fail…that’s why he want to rebuild his oem one
  5. Oct 4, 2021 at 12:52 PM
    Jeffro22
    probably, Just worried now that these are cheap remans and not worth dealing with
    landphil[QUOTED] likes this.
  6. Oct 4, 2021 at 12:53 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just get a rebuild kit from dealer
  7. Oct 4, 2021 at 1:07 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would bet if you pulled that remanufactured caliper apart that you'd find a damaged piston. Have you pulled your apart? If you just need the rubber bits replaced it's not that much of a job.
  8. Oct 4, 2021 at 1:15 PM
    crewmaxlmt
    scott
    If the piston is damaged then it will just do the same to the new seal. Do the repair kits come with new pistons?
  9. Oct 4, 2021 at 1:44 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Nope
  10. Oct 4, 2021 at 1:59 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Raybestos sells new calipers called Element3 that are available at rockauto for about $112 each. Quality is usually good on these. If calipers from Toyota are too expensive, these would be my choice.
    The parts store remans are hit and miss. Often they are ok, but what a headache when they aren't.
  11. Oct 4, 2021 at 2:05 PM
    timsp8
    NY
    Don’t throw money at something that might not work. Just get a new oem one and swap it out.
    crewmaxlmt likes this.
  12. Oct 4, 2021 at 2:08 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Brakes aren't something I cheap out on, ever. Buy factory calipers, or high quality aftermarket ones.
  13. Oct 4, 2021 at 2:55 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    All he need to do is buy a factory rebuild kit and check his oem original calipers and rebuild it
  14. Oct 5, 2021 at 5:49 AM
    Jeffro22
    Oem caliper made it 260k miles. Aftermarket reman about 6k
  15. Oct 11, 2021 at 2:11 PM
    Jeffro22
    Got caliper swapped out. T
    Sucks but this leak has ruined the paint on the Wheel
    went ahead and swapped out with a reman until I can rebuild the oem. Hopefully it will hold Up a little while. Sure made a mess.
    did notice this. Any ideas on what caused this chunk to come off the pad?
  16. Oct 11, 2021 at 3:29 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    inspect the rotor... on the inside.. if the rotor failed it probably took your caliper. my rear rotor failed a while back and took my caliper with it.
  17. Oct 11, 2021 at 3:35 PM
    blackdemon_tt
    was your front caliper sticking?? I'm having similar issues with my front ones, already warped a new set of rotors... so they're on the replacement list.. mine are 240k
  18. Oct 11, 2021 at 4:00 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Rock chip or dirt, when dry everything fly off but when it’s wet everything stuck on
  19. Oct 12, 2021 at 3:29 AM
    Jeffro22
    I do think it was sticking. I noticed that wheel had excessive brake dust right before i noticed the leak. when I disassembled everything was soaked in brake fluid and covered in dirt
