Front bearing and hub assembly. What make should I buy?
Discussion in '2nd Gen Tundras (2007-2013)' started by LouMac, Jan 19, 2020.
  1. Jan 19, 2020 at 7:59 PM
    LouMac
    LouMac [OP] New Member
    After 230k miles the front driver side bearing needs replacing. I'm going for the full hub assembly.
    I'm looking for a little advice on the best make to buy, Dorman, DTA, Timkin? Something else?
    I want something decent. Definitely not crap, but don't need top of the line either unless its price is right.
    I have 2008 4wd 5.7.
    Thanks in advance.
  2. Jan 22, 2020 at 5:19 AM
    Temkins are really good but the OEM price isn't bad either. I pulled this for the 2008 SR5 with the 5.7. https://www.sparksparts.com/auto-pa...7l-v8-gas-engine/brakes-cat/front-brakes-scat
    LouMac[QUOTED][OP] likes this.
  3. Jan 22, 2020 at 5:32 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Just came over from a 4Runner with plentiful full assemblies. Looks like the Tundra has super limited options for complete front hub + wheel bearing assemblies. Even Rock Auto only shows 3 of such, of which I would only buy the Beck/Arnley and avoid the cheaper ones.
    If you were going to press fit, I'd say Timken, SKF, or Koyo wheel bearing and reuse your hub.
    I watch too much Eric with SMA to avoid Dorman unless you're in a pinch.
  4. Jan 22, 2020 at 1:49 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    If you are doing the drivers side you might consider doing the ECGS bushing too.
    Apollothetundra likes this.
  5. Jan 25, 2020 at 5:31 PM
    LouMac
    I bought the Beck/Arnley. Will put them on next weekend. Thanks for the tip.
  6. Mar 8, 2020 at 7:01 AM
    Knolls67
    Knolls67 New Member
    any updates on the Beck/Arnley quality/install/etc? about to pull the trigger and was wondering
  7. Mar 8, 2020 at 10:38 AM
    LouMac
    The Beck/Arnley look identical to the original. Fit perfectly. Run great. If needed I will use them again.
  8. Mar 13, 2020 at 1:06 AM
    Apollothetundra
    Apollothetundra New Member
    Trevor
    07 Super White 5.7l V8 295,000
    I agree . I replaced the needle bearing on mine with that bronze bushing
