Front axle
Discussion in '2.5 Gen Tundras (2014-2021)' started by ElBearded87, Aug 25, 2023.
  1. Aug 25, 2023 at 6:40 PM
    ElBearded87
    ElBearded87 [OP] New Member
    2016 tundra SR5 crew cab 5.7L TRD offroad
    I was told my front CV Boots are starting to leak and I’ll need to replace the front axle for around 13-1400. I was already considering modifying the suspension. Suggestions or ideas if I’m already doing work there? I don’t want or need some big lift, but I like the idea of a 2-3” in the front. Thanks!
  2. Aug 25, 2023 at 6:49 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    $1300 seems wildly expensive to replace a CV Axle. As far as a lift goes, that will be driven by your budget. Shop around at SDHQ.com, they have quite a few options for our truck. And welcome to the forum as well!
  3. Aug 25, 2023 at 6:50 PM
    blenton
    blenton New Member
    If it’s just the cv boots, you can get a CV rebuild kit with new boots, grease, and clamps, for a little over $100. I would suggest having them rebuilt rather than replacing the axles/half shalfts/cv axles unless you go with a Toyota genuine part. The factory parts are robust and overbuilt. Aftermarket parts can be hit or miss, IME.
    For the rebuild, you still need to remove them from the vehicle making it somewhat labor intensive if you take it to a shop. 1300 sounds a little steep, but that depends on where you, I guess.
    ElBearded87[OP] likes this.
