Front and rear differential and transfer case change
Discussion in 'General Tundra Discussion' started by 2020cement_tundra, Jun 28, 2024.
  1. Jun 28, 2024 at 6:11 AM
    2020cement_tundra
    2020cement_tundra [OP] New Member
    Nick
    SC
    2020 tundra
    Hello, I have 31k on the truck and getting quotes to do the fluid changes. I’ve read on here 2-3 hundred but I’ve got two quotes the dealership is $800 and and independent shop is $1,000. Did I misread or misunderstand something? What are you guys paying? Thanks
  2. Jun 28, 2024 at 7:54 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Most dealers charge around $1000 for that. Total rip off given how easy it is. Fluids are pretty expensive. I changed them myself and if you stick to OEM, they are pricey. The Toyota 75W for transfer case alone is 75 bucks.
  3. Jun 28, 2024 at 8:20 AM
    It’s a couple hundred to do it yourself with quality lubricant.
  4. Jun 28, 2024 at 8:36 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    ordered some amsoil (I'm a dealer) for the rear diff and doing it myself...not paying crazy money dealer quoted me too
  5. Jun 28, 2024 at 10:00 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Skip the dealer, always overpriced. Last time I got that done it was about $500 at a local shop, diffs, xfer case, trans drain and fill.
  6. Jun 28, 2024 at 10:04 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    yeah I may get a quote from another local shop. I’m willing to pay $500 but $1,000 is more than I really wanted to spend.
  7. Jun 28, 2024 at 10:12 AM
    JSully
    JSully New Member
    NW Louisiana
    2012 Tundra Platinum
    Blacked out headlights, LED cargo light
    It is not that difficult to DIY. Rear diff is easier than an oil change. Other 2 are a little tighter to get to, but I did mine with the truck on the ground. As stated above you should be able to get the oil for less than $200.
    Pig Rig likes this.
  8. Jun 30, 2024 at 5:44 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    This company sells a kit for diff and transfer case. Oil bottles come with nifty dispenser.
    https://www.blauparts.com/ A lot of members use it.
    iHacker likes this.
  9. Jul 1, 2024 at 12:01 PM
    LateOnTheBrakes
    LateOnTheBrakes New Member
    Charlottesville, VA
    2021 Voodoo Blue Platinum
    TRD exhaust, TRD skid plate, TRD pro wheels, TRD sway bars, AIRAID intake
    It's a few hundred and the job isn't hard if you have a fluid transfer pump or get the little bags of gear oil. The transfer case was the uber expensive fluid on the 2nd gen if you bought the OEM fluid.
  10. Jul 1, 2024 at 12:18 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I fought with a Slippery Pete Fluid Pump when refilling my transmission because the caps didn't fit right, I just did a fluid change on my wife's truck this past weekend and bought a pump sprayer from Home Depot, cut the spray nozzle off the end, heated the plastic wand with a heat gun and bent it 90°, put the transmission and transfer case fluids in that (cleaning between each fluid of course) and that worked so much better.
  11. Jul 1, 2024 at 12:20 PM
    LateOnTheBrakes
    Charlottesville, VA
    I paid the extra money for the motive products power fill tool and have no complaints.
  12. Jul 1, 2024 at 12:21 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    This is where I bought the fluids for my front and rear diffs and transfer case as well.
  13. Jul 1, 2024 at 12:25 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I do have their power fill tank for doing brake fluid flushes and really like it. I did go with Speedi-Bleed reservoir caps and quick connects for our trucks but bought the adapter Motive sells for our boat trailer.
    But for filling the transmission and that, I don't know if another $80 is worth it, for me anyway
  14. Jul 1, 2024 at 1:48 PM
    yakeng
    I had the same dang problem with the Slippery Pete thing. I can't believe it has such good reviews, it's a piece of crap. It's clumsy and slow. I used a fluid transfer pump instead which was way faster.
  15. Jul 2, 2024 at 8:58 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    ...Am I the only one just filling the components from the standard gear oil bottle? I don't recall any issues or messes in the past.
    Really just use a transfer pump when emptying a reservoir which doesn't have a drain.
    I DO have to get fancy for filling the transmission and break out the skinny funnel and some clear tubing.
  16. Jul 2, 2024 at 9:21 AM
    yakeng
  17. Jul 2, 2024 at 10:02 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    For the gear oil in the differentials, I just used the bottles as they had a plastic tube to funnel the fluid into the fill hole.
    I will use the pump sprayer to fill the transmission the next time as it was a lot easier and only cost $10
  18. Jul 4, 2024 at 9:18 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Rear differential is a 10 minute job if you use gear oil that comes in bags. This is the only time I'll use an Amsoil product as the juice is worth the squeeze (literally so easy and mess free). I'm only at 21k miles so I haven't done the front. I did the rear really early because I tow frequently.
    On the front, it was recommended here to replace the drain and fill plugs with a version with a hex head on them. Toyota part number 90341-24016 for the drain and 90341-18060 for the fill. I have these on hand when I do my front. Allen head plugs suck and they always seem get some level of damage when removing them. I stripped the 8mm Allen on my Subaru's front diff fill plug; fortunately on that car you can stuff a hose in the check port and fill it so I just skipped extracting it entirely.
