From Virginia Beach
Discussion in 'New Member Introductions' started by Nmanning556, Jan 15, 2019.
  1. Jan 15, 2019 at 4:25 PM
    Nmanning556
    Nmanning556 [OP] New Member
    VA
    2015 Crewmax SR5 4x4
    Hey all, I've owned my 2015 Tundra Crewmax for about a year and need a place to learn about all the good aftermarket stuff, as well as some of the technical bits (like backwards compatible parts between years of the same generation. )
    I've been working on Lexus products for about ten years now and I'm beyond familiar with the Toyota product overall. Will be glad to lend my experience and knowledge to the DIY crowd. Also have access to Toyota technical manuals...
  2. Jan 15, 2019 at 4:27 PM
    Welcome from Texas
    Nmanning556[OP] likes this.
  3. Jan 15, 2019 at 4:29 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Pinay and Nmanning556[OP] like this.
  4. Jan 15, 2019 at 4:34 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!!
  5. Jan 15, 2019 at 4:38 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  6. Jan 15, 2019 at 4:44 PM
    Welcome from CO..
  7. Jan 15, 2019 at 4:44 PM
    Welcome
  8. Jan 15, 2019 at 4:52 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  9. Jan 15, 2019 at 5:15 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome!
  10. Jan 15, 2019 at 5:22 PM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    Welcome from Virginia Beach!
  11. Jan 15, 2019 at 5:23 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from SIn City!
    I’d be interested to know where’s the best place to get a speaker wiring schematic for the 3rd gen tundras. SPecifically the model year 16, in case they’re different.
  12. Jan 15, 2019 at 5:23 PM
    Welcome from NY.
  13. Jan 15, 2019 at 5:32 PM
    Nmanning556
    VA
    I'd have to look into it when I get into work. It's probably pretty straight forward. What speakers were you going to change?
    Pinay likes this.
  14. Jan 15, 2019 at 5:32 PM
    Welcome from Ohio!
  15. Jan 15, 2019 at 5:41 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I ordered some Focal component for the front and rear doors and an EQ to go with my subs. If it’s too much trouble don’t worry about it, I am mostly curious in case we need to solder in the tweeters cause they don’t come with wire harnesses. I’m having it professionally installed but was going to help the guy since he is a friend and going to do it in my driveway.
    Edit: I’m having him disconnect the dash speakers alltogether as well. The stock speakers just suck.
    Pinay likes this.
  16. Jan 15, 2019 at 5:42 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Welcome form Virginia Beach!!
    Nmanning556[OP] and Pinay like this.
  17. Jan 15, 2019 at 6:05 PM
    Nmanning556
    VA
    I've done something similar without a schematic. My wife's old Hyundai Santa fe, I installed two ways in and soldered the factory connectors to the new speaker leads. Just hook them up and test them before reassembly. If it sounds wrong, just snip the wires, flip them and solder them again. Alternately you could take a multi meter and see which wire is your positive as you go through it, just turn it to accessory and see which wire is hot.
    040Tundra[QUOTED] likes this.
  18. Jan 15, 2019 at 7:01 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  19. Jan 15, 2019 at 7:35 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from NC.
  20. Jan 16, 2019 at 1:37 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  21. Jan 16, 2019 at 3:03 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Welcome fellow va beacher!
  22. Jan 16, 2019 at 6:06 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
