Fridge Repair help
Discussion in 'Off-Topic Discussion' started by FirstGenVol, Dec 24, 2019.
  1. Dec 24, 2019 at 5:21 AM
    FirstGenVol
    FirstGenVol [OP] Check the name tag. You're in my world now.
    East TN
    2002 AC TRD 4x4 V8
    I may have accidentally killed my mini fridge. I was busting up ice last night and my fridge started making a weird noise, then it started putting out a terrible odor. It's not a burning smell, more like a chemical smell. It's not cooling any more either but it's definitely on and running.
    I'm going to open up the back today. Any thoughts on what I should be looking for?
    @bmf4069 aren't you an electrician? Help me :D
  2. Dec 24, 2019 at 5:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Forgot to post pics. I may have bumped that white tube.
  3. Dec 24, 2019 at 5:24 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    AC refrigerant has a chemical, sweet smell. You busted a refrigerant line. Cheaper to just buy a whole new fridge.
  4. Dec 24, 2019 at 5:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Bummer. Most likely the white line that runs up from the bottom there?
  5. Dec 24, 2019 at 5:36 AM
    Danman34
    Danman34 New Member
    Danny
    Yep. The temp sensor is telling the compressor to kick on but there’s nothing to circulate. The refrigerant also lubes and cools the compressor. It will just burn up without refrigerant. By the time you take the thing apart and replace the line, pull vac and fill with new refrigerant, you could have bought a new $50 mini fridge lol
  6. Dec 24, 2019 at 5:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Lesson learned. The weird thing is that the line looks intact. It's not loose or punctured. It's like it came loose down below, where I can't see.
    NewImprovedRon likes this.
  7. Dec 24, 2019 at 5:48 AM
    Danman34
    Danman34 New Member
    Danny
    Probably broke it at the fitting. It’s most likely cheap, thin copper tubing with a compression fitting. Doesn’t take much to break it at the connection.
  8. Dec 24, 2019 at 11:16 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm with danman on this one. But just be be sure, hit it w/some 240 to make sure it's dead.
  9. Dec 24, 2019 at 11:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    She's dead Jim...sad day.
  10. Dec 26, 2019 at 1:41 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Freon is oily and you should have heard a loud hiss due to the high pressure. The 3/8 in plastic tube going to the top should be the drain tube for the defrost cycle.
  11. Dec 26, 2019 at 1:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah. I realized what I did. While scraping the ice I punched a hole in the paper thin ice tray. I had no idea refrigerant ran through that thing. Really careless move on my part.
    Guess who is buying a new fridge now?
  12. Dec 26, 2019 at 1:44 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Your "sealed" system is no longer a "sealed" system...:(
  13. Dec 26, 2019 at 2:17 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    No need to confirm it's DOA but get a smoke tube from Amazon and use it as a cold smoker. Cheeses and nuts.
  14. Dec 26, 2019 at 2:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ha! I took out 2 mini fridges at work puncturing the thin ice tray with a hammer and chisel. It’s ridiculous how easy it punctures. It’s like made from aluminum foil. Second time I knew how easy it was to puncture and still did it again. :facepalm:
