Freedom Off-road UCA QUESTION
Discussion in '1st Gen Tundras (2000-2006)' started by PA Tundra, May 3, 2024.
  1. May 3, 2024 at 8:04 AM
    PA Tundra
    PA Tundra [OP] New Member
    2006 Tundra TRD
    OME Lift, upper control arms, Frame swap
    I have 2006 Tundra and I purchased the Freedom off-road arms when on sale. I am wondering if anyone has information on what the thread size and pitch is for the ball joint?
  2. May 3, 2024 at 8:21 AM
    shifty` In South Dakota Trouble ain't hard to find
    General consensus are their mediocre arms from a garbage company. I remember a bunch of people on here weren’t happy with them, and lukewarm on the product.
    Do you have the UBJ in hand? All local Ace Hardware stores I’ve been in have a thread gauge (I have my own, cheap enough to buy), and I’d their gauge in the nuts/bolts section doesn’t go high enough you could always hit the blunts section until you find the right size.
  3. May 3, 2024 at 8:28 AM
    PA Tundra
    2006 Tundra TRD
    I do not have them in hand, on truck. I didn't know if someone has switched to a castle nut by chance or used the nylock nut it came with. Just trying to run to the store to get one
  4. May 3, 2024 at 8:33 AM
    I only know off-hand of one person running them for sure, @bmf4069 I believe. I’d tell you to call Freedom and ask them but after what others experienced it may be a lost cause. Still, I’d try! You bought their product, they should support it.
    That said, is their balljoint spindle drilled for a cotter? If it is, I’d stick with castle.
  5. May 3, 2024 at 9:10 AM
    PA Tundra
    2006 Tundra TRD
    They messaged me back and it's an M14x1.5 but yes it's drilled for a cotter but comes with a nylock
    shifty` likes this.
  6. May 3, 2024 at 10:45 AM
    vst
    vst New Member
    Scott
    East TN
    2005 DC 4wd
    I’ve been running them on mine they’ve been all good I used the nylock nut no issues so far. You may need to grease the ball joint though even though they say they come pre greased.
    shifty` likes this.
