Free oil change from Toyota.
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Mar 6, 2023.
  1. Mar 6, 2023 at 3:23 PM
    eagleguy
    eagleguy [OP] New Member
    Well I got my last free oil change from Toyota under the 2/24 program. Got them to do 20k change at 15 miles due to the time. They normally got $115 plus tax so free was good!
  2. Mar 6, 2023 at 3:49 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Free with $50,000 truck
    Rocko9999 and BravoDeltaRomeo like this.
  3. Mar 6, 2023 at 4:18 PM
    Dukhnt
    Dukhnt New Member
    Free isn't necessarily a good thing - especially when it comes to a 15 dollar an hr guy changing your 50k truck oil.
    My OCD would never allow this. Hopefully they did a good job.
    2mchfun, Joe333x and coldcanuk like this.
  4. Mar 6, 2023 at 4:29 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Have you gotten under your truck and checked all the bolts for proper torque? Or that they're all there?
  5. Mar 6, 2023 at 4:32 PM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    dollars to donuts one of the front three Phillips screws holding on the skid plate is gone and things are way too tight or way too loose.
    Dealerships........
    BravoDeltaRomeo likes this.
  6. Mar 6, 2023 at 4:50 PM
    eagleguy
    A: Nobody at my dealership in the Service Dept. makes $15 and who said anything about 50K??????
  7. Mar 6, 2023 at 5:04 PM
    Dukhnt
    Dukhnt New Member
    I was talking about the estimated cost of your Tundra when I referred to 50k.
    Not sure what you expected people to say? Obviously a lot of us don't trust anyone else to get things perfect with this task.
    If your dealership pays above minimum wage for the oil guy and you are happy you got it free, then we are obviously very happy for you.
    coldcanuk likes this.
  8. Mar 6, 2023 at 5:14 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Yeah he probably torqued your filter housing to 250 ft-lbs with his impact gun…
    Rocko9999 likes this.
  9. Mar 6, 2023 at 5:53 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    I’ll play devil’s advocate, dealership up here did my sensor gasket recall bs and gave me my last and only oil change (did everything myself til that point), I bit. I spent ten minutes in the parking lot under the hood and truck double checking fluid levels, bolts, housing not cracked, crush washer in place, etc anyways before I left which was dumb. They actually did a good job though and I didnt need a ten foot breaker bar to get the filter housing off at the next change. Its the exception instead of the rule though.
    Have never had anyone change my oil except me before and never will again though. Control issues. :rofl:
  10. Mar 6, 2023 at 6:00 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Yep I don't even like taking my Tundra for inspection. :pout:
    RustyShackle323 and FlyingWolfe like this.
  11. Mar 6, 2023 at 6:15 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    They probably… didn’t change the oil filter cartridge…
    2mchfun likes this.
  12. Mar 7, 2023 at 3:39 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    They definitely tightened the plastic oil filter housing until it cracked, backed it off a quarter turn and called it good
    Rocko9999 and FlyingWolfe like this.
  13. Mar 7, 2023 at 4:40 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You trust the 15 dollar an hour guy to safe handle your food that you put in your body?
    Dukhnt[QUOTED] and hagrid like this.
  14. Mar 7, 2023 at 5:00 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Or the $15/hr gal at the Chinese Golden Fingers massage?
    Bammer, PomDad, AZBoatHauler and 3 others like this.
  15. Mar 7, 2023 at 5:07 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    We can always count on you for a good chuckle.
    hagrid[QUOTED] likes this.
  16. Mar 7, 2023 at 6:15 AM
    Dukhnt
    Dukhnt New Member
    My body is about 1/3 as important as my Tundra.
    PomDad likes this.
  17. Mar 7, 2023 at 6:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Good luck with that lol
    Dukhnt[QUOTED] likes this.
  18. Mar 7, 2023 at 9:51 AM
    Rocko9999
    Rocko9999 New Member
    Dealer supplied oil drain plug install tool-
  19. Mar 7, 2023 at 1:22 PM
    eagleguy
    Wow. Just was saying I got in an extra oil change. As I do some side work at the dealer I can say there is NO $15 doolar guy assigned oil changes, at least where I go. In the end I am happy.
    NewImprovedRon, 27bluenote and hagrid like this.
  20. Mar 7, 2023 at 1:42 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I thought that was the filter installer :D
    Glad you’re happy op what year is your truck
    Rocko9999[QUOTED] likes this.
  21. Mar 7, 2023 at 1:46 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That’s all that matters!
  22. Mar 7, 2023 at 1:54 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    That's what the gal at Chinese Golden Fingers says!!
  23. Mar 7, 2023 at 1:57 PM
    AZBoatHauler
    So.Arizona
    hagrid and 27bluenote like this.
  24. Mar 8, 2023 at 7:54 AM
    Wheresmytranscooler
    Wheresmytranscooler New Member
    Brad
    2019 Tundra SR5 TRD
    Check the skid plate bolts, they always get cross threaded.
  25. Mar 8, 2023 at 1:04 PM
    eagleguy
    I have the aftermarket skid plate with door. All is good! When its my turn I will go the Fumotto route.
    NewImprovedRon and Leo's first like this.
