Thread Status:
Not open for further replies.
  1. Oct 24, 2022 at 11:07 AM
    FirstGenVol
    FirstGenVol [OP] Check the name tag. You're in my world now.
    East TN
    2002 AC TRD 4x4 V8
    Tundra2, shifty` and richsadams like this.
  2. Oct 24, 2022 at 3:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    They fit a large flatrate box?
  3. Oct 24, 2022 at 6:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can take some measurements but my guess is no. I thought you already had 14WA's?
  4. Oct 24, 2022 at 9:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I do. On the shelf lol.
    Haven't found time to install them, with other projects needing to be done. Sisters cr-v, hr-v and old del sol needed work this last couple months. I've been building my brother in laws twin turbo fox body (again) since June. Pulled it and built another motor (cause he blew it). Which turned into a bit of a project, as that got different heads, cams, rockers, etc. He also decided to do a tubular k-frame, we had to figure out a 6 speed swap as well (modified a gm t5 adapter plate to work with a ford t5 bell housing, since he ordered a plate that doesn't fit and no one currently makes). He pulled the dash to refinish it and now I'm playing with almost 20 year old dash wiring to reduce the number of switches and gauges, because it's also getting a digital dash conversion (which also needs wiring done).
    Anyways, if no one else wants them I can take a look and see if they're salvageable.
    Sunnier and des2mtn like this.
Thread Status:
