Freaking out. May be nothing
Discussion in '2nd Gen Tundras (2007-2013)' started by Tallmaan84, Oct 30, 2024.
  1. Oct 30, 2024 at 11:26 AM
    Tallmaan84
    Tallmaan84 [OP] New Member
    After enjoying ya'lls threads and opinions for many years, I might have a problem. The truck has aged from 110k to 130k since I bought it in 2020. I have kept up with regular maintenance and before we moved I did the drain fill on the transmission. However, lately, I have noticed the transmission is shifting a little bit rougher than I remember previously. It did two 5k lbs. for 16 hours and did it like a champ, but I am concerned the transmission is going to start acting up here soon as the shifting has gotten barely noticeable. It smoothed out to nothing after the fluid exchange and it has gotten rougher since then. Am I freaking out about nothing or would this be concerned? I am looking to also upgrade a few parts on the truck as well and am trying to get ahead of any noticeable things wrong instead of investing money in upgrades. Thanks so much for your help!
  2. Oct 30, 2024 at 11:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Are you sure the fluid level is correct?
    If it was me, I would probably drain and fill it again for safe measure and then ensure the fluid level is correct (OBD2 temp gauge, IR thermometer, or short out the OBD2 pins).
    Mdl and mountainpete like this.
  3. Oct 30, 2024 at 11:30 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Tell us more.
    Is the transmission clunking, jerking, grinding or shifting slow?
    Which gear is it most commonly happening in and at what RPM?
    Is the roughness in an upshift or downshift?
    Any tire changes recently?
  4. Oct 30, 2024 at 11:35 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Was your truck level when you filled it? You could be a little low on fluid. Recheck and see if its a nice trickle not a dribble. You can also add a 1/2 quart extra as the pan can accommodate extra fluid. I always add 1/2 to 3/4 quart after the trickle check.
    Good luck.
  5. Oct 30, 2024 at 5:18 PM
    Tallmaan84
    Not clunking or jerking. No tire changes.
    i used a cheap drain pan to measure how much came out. It was 4 quarts overfull. So I drained it to a drizzle. The truck was level and the driveway was as good as it gets. I’ll pull the plug after this weekend
    Mdl[QUOTED] likes this.
  6. Oct 30, 2024 at 5:19 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I imagine our motor oil pans would accommodate more oil too. I would not suggest overfilling either.
    I personally would perform another drain and fill (as suggested) with the correct fluid, and using the correct leveling procedure. Then you'll KNOW it's done properly, without adding fluid all willy nilly.
  7. Oct 30, 2024 at 6:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I agree and only state that as I've been doing it for quite some time now. Sometimes it does alleviate some shifting issues. Although could also be from a fill that was off.
  8. Oct 30, 2024 at 6:40 PM
    blenton
    blenton New Member
    This.
    To add, how often do your u-joints get grease? Driveline slack - including soft springs - can imitate transmission shifting issues. Before you do anything else, I’d grease the u joints (assuming you have zerk fittings on thr joints; I don’t remember what year they stopped installing them but maybe 2018?) and drive around the block. My transmission always ‘shifted smoother’ after I grease the zerks.
    If your springs are worn and tired, they can have a little bit of wrap between shifts that will feel like rough transmission operation. Throw some weight in the bed and take it around the block. See if it changes anything.
    5k lbs for 16 hrs isn’t a big deal unless you were running with the converter unlocked the whole time and smoked the fluid from excessive heat. I’ve prolly done that much towing this month alone and the transmission is still happy. Last month was almost that much at max trailering weight. :eek:
    Still, I would take the advice of doing another drain and fill. It won’t hurt anything, and it will give you an idea of how the fluid is holding up.
    Mdl likes this.
  9. Oct 31, 2024 at 2:43 AM
    Tallmaan84
    I hadn’t thought about the U-joints! I figured the towing wasn’t an issue, but drain and fill might not be a bad idea. Probably won’t do the usual 16 qts. The springs you referenced are the leaf springs?
    blenton[QUOTED] likes this.
  10. Oct 31, 2024 at 3:53 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    When I didn’t grease my u joints it felt like I had a transmission issue. Greased them every oil change after I figured it out
    blenton likes this.
  11. Oct 31, 2024 at 6:19 AM
    blenton
    blenton New Member
    Yes, the leaf springs. As they wear and flatten out a little, they don’t resist the axle torque as well and can wind up a little bit causing a small degree of axle wrap.
  12. Oct 31, 2024 at 6:24 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    How are you getting 16qts on a drain and fill?
  13. Oct 31, 2024 at 7:25 AM
    COTundie
    Trey
    Pretty things
    When people reference a transmission "Drain and Fill", it is draining ONLY THE PAN and will generally yield around 4 quarts removed and replaced. I believe this method is designed to avoid "shocking" the system with a complete replacement of ATF. I think a full fluid swap is probably a lot safer than a pressurized flush (at higher mileage), but still leaves room on the table for subsequent transmission problems.
    So you probably don't need to do an actuall drain and fills but I would absolutely toss a quart in and perform the recommended leveling procedure to ensure you have the proper amount of ATF.
    I also hear these Aisin transmissions are kinda picky about fluid types so I only use Toyota WS ATF in my tundra.
  14. Oct 31, 2024 at 7:35 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did you check the level cold? Or hot? if you checked it cold, after refilling it, odds are you are really low on fluid. I did the level check cold without running it to the required temperature and had to refill it since there was nothing coming out of the check valve. Turned out all the fluid I dropped in, it spat out...
