Freaking Low Payload
Discussion in 'Towing & Hauling' started by CaptCraig, Jun 9, 2021.
  1. Jun 9, 2021 at 1:18 PM
    CaptCraig
    CaptCraig [OP] New Member
    Craig
    2021 Tundra CrewMax 4x4
    I'm concerned we are very easily over our patheticly low payload. The car & RV dealership both gave me false sense of security. With a wife, four small kids & dog totalling 670 lbs, my payload gets eaten up quick. The only solutions I have are removing the tonneau cover when towing & filling the gas tank less. Driving separate isn't an option with gas prices these days. Any tips on lowering payload weight? Does the WDH help with anything? Taking it all to get weighed this week.
    Edit: I have a husky WDH that is rated for 800-1,200 lbs.
  2. Jun 9, 2021 at 1:23 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Airbags would be the answer to your problem
    Bigboitundra likes this.
  3. Jun 9, 2021 at 1:24 PM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    What's the payload on your Tundra and what is the hitch weight on the trailer? A WDH will just distribute the weight therefore the ass end of the truck wont sag as much it will also help with sway. Here is a helpful link I used when I finally decided it was time to upgrade to a 3/4 ton http://towcalculator.com/
  4. Jun 9, 2021 at 1:24 PM
    Nightshade Tundra
    Alex
    Airbags = More weight
  5. Jun 9, 2021 at 1:25 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Those don't increase your payload capacity...
  6. Jun 9, 2021 at 1:29 PM
    Professional Hand Model
    Hand Protectors
    Remove AC Compressor, door skins, floor mats, loose change in cup holder, etc.
  7. Jun 9, 2021 at 1:34 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    I thought his issue is with truck sagging when towing. Tundra can handle a lot more with airbags. But if you're towing "2 bedroom apartment", you got the wrong truck :D
  8. Jun 9, 2021 at 1:36 PM
    CaptCraig
    Craig
    1335 after hitch weight is taken out. Hitch weight is estimated around 600 lbs, getting it weighed this week. Every spreadsheet I fill out had me at least 200 lbs over. But that was with 75 lbs of wood & 50 lb tonneau cover that will go in the travel trailer next time.
  9. Jun 9, 2021 at 1:37 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Where did he say anything about sag?
    Just because the truck doesn't sag doesn't mean it can handle more. You can't increase the GVWR beyond 7200 lbs.
  10. Jun 9, 2021 at 1:45 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Our Tundras are the heaviest 1/2 tons out there. All those quality components eat up the GVWR.
    oddhours and Cpl_Punishment like this.
  11. Jun 9, 2021 at 1:49 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    If your hitch weight is actually around 600lbs you can probably just make it within rated payload. Will need to basically keep the truck empty except for people and load everything else in the trailer. Will need a WDH and most also have sway control. Probably a good idea to buy a hitch scale off Amazon so you can dial in your hitch weight by moving items within the trailer. You need to make sure your hitch weight is 10-15% of the trailer weight for proper control. What are the specs on the trailer?
    CaptCraig[OP] and Cpl_Punishment like this.
  12. Jun 9, 2021 at 1:49 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Personally if I were pushing the limits statistically I would certainly invest in a WDH as it will help (although add weigh) but it re distributes the weight back to the front tires of the truck and the trailer axles and sort of locks the 2 together as 1.. Typicality they also have sway control built in, so IMO from a safety standpoint pro outweighs the con.. not a bandaid like a airbag...
  13. Jun 9, 2021 at 1:53 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    I frequently drive with pallet of porcelain tile in trucks bed, i have sumosprings installed to help with squat. My truck also has ARE topper, never had an issue. Those trucks can handle more weight than it is written in your manual, with proper suspensions mods and assuming you have 5.7. And if you towing a lot fully loaded, that is a different subject of discussion
    Terndrerrr, rockmup and CaptCraig[OP] like this.
  14. Jun 9, 2021 at 1:54 PM
    Nightshade Tundra
    Alex
    Don't they recommend that when towing to try and be at 10-15% below the limits of the vehicle that is being used to tow?
  15. Jun 9, 2021 at 1:56 PM
    CaptCraig
    Craig
    I bet my farmer father-in-law has a hitch scale or my brother-in-law works for a grain elevator too. Trailer specs are GVWR 7680, UVW 5140. Only other weight would be the two LP tanks on front. My biggest issue is the 670 lbs of family members taking up a large portion of my payload.
  16. Jun 9, 2021 at 1:57 PM
    Nightshade Tundra
    Alex
    A pallet of porcelain wont get pushed around by the wind when traveling as much but a tall camper would. I have no doubt that the Tundra can tow more than what the manufacturer suggest or take on a higher payload. It all comes down to safety and also not being able to load anything in the bed.
  17. Jun 9, 2021 at 1:57 PM
    CaptCraig
    Craig
    First thing we did was have the RV dealership install a WDH rated from 800-1200 lbs. It's the only thing keeping me sane right now.
    Johnders2586[QUOTED] likes this.
  18. Jun 9, 2021 at 2:00 PM
    Nightshade Tundra
    Alex
    Take it to the scale like you said that's the best thing you can do. I personally think your right at the limit or over it. Do you plan on towing up a mountain or mostly flat land?
    jordoncloutier likes this.
  19. Jun 9, 2021 at 2:00 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    That is exactly what i wrote, if OP tows a lot and heavy, he needs a different truck
    CaptCraig[OP] and rockmup like this.
  20. Jun 9, 2021 at 2:09 PM
    CaptCraig
    Craig
    Yeah, all the numbers look amazing with plenty of room to spare with GVWR for the the truck & travel trailer. I just can't make the payload work without some serious inconveniences. Just trying to keep the wife & kids from driving separate.
  21. Jun 9, 2021 at 2:21 PM
    A-A-Ron
    Aaron
    Seattle
    I would assume you would be in under 6,500 fully loaded but without carrying water. Would need to dial in the hitch weight to 650. It can work with careful planning and packing light. Be sure to get a Scan Gauge or something else to monitor transmission temperature, especially since your 2021 doesn’t have a factory trans cooler. Drive in S mode, S4 on hills keeps the temps down.
    I did a 32’ trailer for a year before going to a 3/4 ton. I’m assuming you must be about 28’ from hitch to bumper, it’s about as big as I would go with a Tundra.
  22. Jun 9, 2021 at 2:32 PM
    Nightshade Tundra
    Alex
    I really hope Toyota adds a temperature gauge to the 2022 model it irritated me that I couldn't keep an eye on my temps in my Tundra
  23. Jun 9, 2021 at 2:39 PM
    A-A-Ron
    Aaron
    Seattle
    Had my Scan Gauge mounted on the steeling column, not ideal but it worked well. Install was easy but it took a little time to get the codes figured out on the setup. Can show four different readings at once, two sensors for the tranny.
    CaptCraig[OP] likes this.
  24. Jun 9, 2021 at 3:02 PM
    CaptCraig
    Craig
    I don't typically drive past the borders of the midwest, so likely not making it past
    Got a WDH for the sag. Just realized this week my payload capability was that of a prius.:(
    ZappBrannigan likes this.
  25. Jun 9, 2021 at 3:02 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    If it truly concerns you that much then you should buy a bigger truck. All the math in the world won't help you with your fears.
    Gravy, jb04, farm&forest and 2 others like this.
  26. Jun 9, 2021 at 3:12 PM
    18" TRD Off Road Wheels
    Generally speaking, if you want to tow bigger than 22'-24' LIGHT trailers, you're better off with a bigger truck. No half tons are really going to be more than a few hundred pounds ahead of the Tundra.
    If you want to go diesel get a 1 ton, because the heavy engines smoke a 3/4 tons payload. You'll find yourself in pretty much the same boat otherwise.
    You have to decide if you want the truck or the trailer more, then select the other to fit it.
  27. Jun 9, 2021 at 3:15 PM
    Nightshade Tundra
    Alex
    Here are the towing numbers on my truck not trying to convince you to go to a 3/4 ton just info. I went from 1130lb payload and 8800lb of towing to this
  28. Jun 9, 2021 at 3:21 PM
    CaptCraig
    Craig
    yeah, 28 ft Forest River Salem.
  29. Jun 9, 2021 at 3:23 PM
    CaptCraig
    Craig
    Doubt we would jump into the world of diesel. As much as I'd love one, I'm barely handy enough to maintain a gasser. Good lookin truck in your pic btw.
  30. Jun 9, 2021 at 3:26 PM
    CaptCraig
    Craig
    I wish it was that easy. We went off the readily available data for towing without a second thought to payload. We'll just have to get creative since this is our first brand new vehicle & truck in general.
    rockmup and GODZILLA[QUOTED] like this.
