Frame rust
Discussion in '1st Gen Tundras (2000-2006)' started by Mark61, May 6, 2019.
  1. May 6, 2019 at 4:32 PM
    Mark61
    Mark61 [OP] New Member
    Mark
    2002 trd
    Hi, new to the forum. Looking to purchase a 2002 tundra trd. Should I be concerned about frame rust issues. The truck is from Wisconsin. Thank you.
  2. May 6, 2019 at 4:40 PM
    Aerindel
    Aerindel New Member
    Montana
    Only if you're purchasing it sight unseen. You either have a problem or you don't, one look underneath should let you know what you have. Its certainly a strong possibility coming from that area but it really just depends on the truck.
  3. May 6, 2019 at 4:46 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If it hasn't been replaced yes. Around the spare tire and front tires.
  4. May 7, 2019 at 9:33 AM
    Mark61
    Mark
    2002 trd
    Thank you
  5. May 7, 2019 at 10:25 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I live in Southern California where rust isn't an issue. I always bring a flashlight & large piece of cardboard to lie on so I can crawl under the vehicle & check it out underneath for rust & leaks.
    FirstGenVol likes this.
  6. May 7, 2019 at 11:15 AM
    Mark61
    Mark
    2002 trd
    What's the percentage of bad ones? I'm starting to have second thoughts about buying one.
  7. May 7, 2019 at 11:21 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    completely depends on the area. My dad has an 02 that didn't have the frame replaced, and after 17 years in the MN salt, it's still just fine. my 2000 was not, and had the frame replaced. It's not as scary as people make it sound as long as you check it out before you buy. It'll be pretty obvious if it's a good or bad one.
    Black Wolf likes this.
  8. May 7, 2019 at 11:22 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Of trucks that spent their whole lives in states that don't salt their roads? 0% In trucks that spent a significant part (or all) or their lives in states that salt their roads? It varys widely. Just inspect before you buy or have someone you trust do it.
  9. May 7, 2019 at 11:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In your area there will be a lot of rusted ones. I wouldn't let it scare you away from at least looking though. These are great trucks so long as you don't buy one that's rusted.
  10. May 7, 2019 at 11:48 AM
    SoCalPaul
    Paul
    Check post # 37 in the link below. It'll show clear pics of different stages of rust. The link should take you directly to the pics. Again, you just need to inspect it first. If you don't think you're knowledgeable on the subject, see if you have a friend who is. Otherwise pay a knowledgeable mechanic or vehicle inspector to check it out for you. You can also post pics & get advise from here.
    In the first pic, some visible rust, wouldn't stop me from buying, but start treating it right away. Second pic - move along. Third pic - run, don't walk.
    Low on the left
