Frame replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Chicken Run45, Nov 24, 2022.
  1. Nov 24, 2022 at 5:56 AM
    Chicken Run45
    Chicken Run45 [OP] New Member
    Marshville NC
    04 silver streak dcsr5
    None YET
    Does anyone know of any dealerships in North or South Carolina that are still doing frame replacement/warranty
  2. Nov 24, 2022 at 6:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    go to toyota and input your vin, see if they are active recalls. If not, you are probably out of luck. I thought that the frame warranty on 1st gens expired long ago. And any trucks that did have any work done, frame cleanup or where toyota sprayed them with undercoat....well that counted as the warranty work so those trucks would not quality for another warranty.
    This may help https://www.tundras.com/threads/early-1st-gen-2000-2003-tundra-frame-replacement-faq.54331/
  3. Nov 24, 2022 at 6:17 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It really has little to do with the dealership and more to do with making sure your truck qualifies. Toyota corporate has to approve the replacement and then they pay the dealership to do the work.
    Jack McCarthy likes this.
  4. Nov 24, 2022 at 6:47 AM
    At least one or two members have found going to diff't dealerships resulted in different results, but I don't remember whether it was an issue of trying to get an inspection or not.
    Needless to say, OP has an '04. Toyota never chose to include '04-'06 in the frame recall, did they?
    FirstGenVol likes this.
  5. Nov 24, 2022 at 6:54 AM
    frichco228
    just checked, you are correct, its for 2000-2003
    shifty`[QUOTED] likes this.
  6. Nov 24, 2022 at 8:35 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I had to drive my truck 2.5 hours to a dealership that I KNEW did frame swaps, as my local dealerships were an unknown.
    Three main reasons for this:
    1. I knew they were experienced at changing frames.
    2. I knew they were WANTING/WILLING to do the job as they had before. My local dealerships are just lube tech/oil change places. Fuck them.
    3. I knew that the dealership would change other things like body mounts, engine mounts, transmission mounts at my cost with reduced labor because they were already taking the whole truck apart.
    I would drive around to different dealerships, and look in the back lot to see if there's frames stacked out back... that'd be a good indicator to see if they actually do the work. Won't hurt to call around either.
    Good luck OP
  7. Nov 24, 2022 at 9:06 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Yeah...Fuck them!
  8. Nov 24, 2022 at 9:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    w666[QUOTED] likes this.
  9. Nov 24, 2022 at 9:12 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I my truck used in Smithfield VA when it was 5 years old. Never though about rust because I live on the Chesapeake and didn’t get snow. I moved to SC a year later but about 5 yrs ago I got a warranty notice and took it in to Scott Will Toyota. They said they removed the bed and didn’t find any significant rust. They had it overnight.
  10. Nov 24, 2022 at 8:12 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    As much as I agree with @Tundra2 if you have a 2000-2003 you'd be set following those instructions but with an 04 you're SOL as others have stated.
    You're options are to find replacement metal for the rusted sections or find a whole replacement frame from a junkyard as Toyota will not sell you one.
