Frame Repair on 2002 Tundra Limited
Discussion in '1st Gen Tundras (2000-2006)' started by Alden35, Oct 15, 2021.
  1. Oct 15, 2021 at 12:54 PM
    Alden35
    Alden35 [OP] New Member
    WILLIAM
    2002 Tundra Limited
    None
    The frame on my 2002 Tundra has rusted through where the rear leaf spring attaches in front of the rear wheels (both sides). I’m thinking of getting a piece of quarter inch steel three inches wide and thirty six inches long and bolting or welding it to the bottom of the frame. I would have to cut out the rivets on my spring mount, then re-bolt the mount to the repair. I could use some suggestions as I’m sure I’m not the first one to have this problem.
    remington351 likes this.
  2. Oct 15, 2021 at 12:58 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  3. Oct 15, 2021 at 1:03 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  4. Oct 16, 2021 at 12:52 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You have your frame inspected by Toyota at any point? Truck not covered under frame replacement recall?
    https://www.tundras.com/threads/early-1st-gen-2000-2003-tundra-frame-replacement-faq.54331/
    Alden35[QUOTED][OP] likes this.
  5. Oct 16, 2021 at 1:50 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  6. Oct 17, 2021 at 3:37 PM
    alb1k
    Left Coast
    It's good
  7. Oct 17, 2021 at 5:25 PM
    shifty` In South Dakota Trouble ain't hard to find
    I'd check to see if Toyota will replace it under their program first.
  8. Nov 1, 2021 at 2:46 AM
    w666
    Maryland
    I found this on FB...
    250620879_4378883292189690_5586911532070_2dfa4991803226d1050838af1af16389a2cf2119.jpg
    Lil Steve, shifty`, bmf4069 and 2 others like this.
  9. Nov 1, 2021 at 4:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  10. Nov 1, 2021 at 6:25 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I certainly hope those are Grade 8 bolts! :rofl::rofl::rofl:
    shifty` likes this.
  11. Nov 1, 2021 at 11:56 AM
    #Fixeditma
    #Goodasnew
