Frame reinforcement brackets
Discussion in '1st Gen Tundras (2000-2006)' started by wildmanwes92, Jun 3, 2024.
  1. Jun 3, 2024 at 7:05 PM
    wildmanwes92
    wildmanwes92 [OP] New Member
    Weston
    Hey Gents,
    I recently purchased a 2004 4wd DC tundra, 250k miles. One owner, Immaculate service records, oil changed every 3k miles, and serviced at Toyota up until I bought it (vin search on Toyota shows timing belt done at 195k).
    Truck runs like a top, and upon initial inspection frame didn’t look bad to me. No holes or perforations and rails look solid. However, once I really started digging after purchase (and reading tons more threads) I see that I have the dreaded stiffener “pooch”, where the stiffener has started to delaminate and bulge from the rivets. Looks exactly like this: https://www.tundras.com/threads/frame-bracket-rust.95349/
    I plan on wire wheeling the frame, spraying with ospho and coating with POR, followed by liberal amounts of surface shield and send it. How much longer do you all think I have before it’d become a major issue? This truck is primarily a wood/mulch/camping truck and would not be driven in the snow (I have an awd Swedish tank for that). I was quoted by a friend who runs a rust repair shop @ $2k to repair both sides but would prefer to forgo it for as long as I can.
    I also found these prefabbed stiffeners but they lack the support of the original stiffeners. https://www.jeffriesmanufacturingll...a-frame-inner-reinforcement-plate-replacement
    Thanks guys!
  2. Jun 3, 2024 at 7:08 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would check with www.autorust.com. Last time I talked to them they were talking about making safe-t-caps for that area. One of our members here cut out the reinforcement and built his own. A lot of work but worth it if you plan to keep it.
  3. Jun 3, 2024 at 7:18 PM
    wildmanwes92
    Weston
  4. Jun 3, 2024 at 8:15 PM
    Jack McCarthy
    Bill
    North of Boston
    That looks like the right area for me at least. I'm not sure about the 06; they may have assumed it's similar. I don't think it replaces the stiffner bracket though.
    I know www.autorust.com will do the work for you or recommend the closest shop to you that works with their caps.
  5. Jun 4, 2024 at 2:23 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I'm the poster of the original thread. I posted this in September of 2021 and as of now, almost three years later, my rivets have not pulled through.
    Jack McCarthy likes this.
  6. Jun 4, 2024 at 5:07 AM
    wildmanwes92
    Weston
    Good to know. Did you coat with POR and fluid film or similar products?
  7. Jun 7, 2024 at 8:59 AM
    remington351
    2006 SR5 DoubleCab
    No. My truck had the black gunk applied from the frame rust inspection/recall from Toyota. I just left it as is.
