Frame recall 2nd gen Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Brijab, Oct 1, 2018.
  1. Oct 1, 2018 at 7:07 AM
    Brijab
    Brijab [OP] New Member
    07 crewmax limited
    Hey folks, new to The Forum. I am getting a new frame on my 07 Crewmax this week and and the dealer has told me that anything I replace underneath will be free labor. I will just need to pay for the parts. Almost 12 years old 96000 miles and I I'm looking for recommendations for age and mileage on what I should be replacing. Of course the factory alternator died last week so that is new. Dealership recommends cats and water pump. Thank you for any recommendations in advance.
  2. Oct 1, 2018 at 7:13 AM
    BIGUGLY
    Paul
    2018 Limited
    Shocks and coilovers would be a hoodnidea
    Brijab[OP] likes this.
  3. Oct 1, 2018 at 7:22 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Look at a-arms and upper and lower ball joints.sway bar bushings ,sway bar links and center support coupling where the two driveshafts connect. I had the frame replaced on my 2000 tundra and they replaced some the parts I mentioned.
  4. Oct 1, 2018 at 7:36 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Get a 38 gallon tank
    Ericsopa, papasmurf and TheBeast like this.
  5. Oct 1, 2018 at 7:49 AM
    Definitely the water pump. If your cats and exhaust are in bad condition I'd change those out too.
    papasmurf likes this.
  6. Oct 1, 2018 at 11:02 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Hearing the starter is a PIA to change. Something to inquire about as well.
  7. Oct 2, 2018 at 7:21 AM
    Brijab
    07 crewmax limited
    Thanks for the input guys. I'm bringing it to the dealer now and they will call me tomorrow with his recommendations. I will be available to go and verify, a questionable dealership that remembers me from '12 when I went to regional VP on rusted out bed when dealer declined replacing. VP approved it and charged dealer because of the way it was handled. They we're not happy but they also know not to play games with me.
  8. Oct 11, 2018 at 11:54 AM
    Brijab
    07 crewmax limited
    For anybody going through this Frame replacement, the parts that were recommended and I have changed are primarily due to the fact that I live in Northern New York mountains with lots of winter weather so most the recommendations were due to rust and imminent failure of parts. I changed the fuel pump computer that sets on the frame as it was almost disintegrated due to rust. I did have the water pump replaced as that takes up a lot of Labor if I need to have it done in the future and the labor was free. I changed the shocks all around and the coolant pipes were very close to failing steering shaft was incredibly Rusty so I changed that and the power steering rack and lines we're all replaced. Finally the e-brake pivots and cables were partially seized due to rust. Total expenses were 9 hours labor and just shy of $3,000 in parts dealer gives 10% military discount so total was just shy of 4 grand. Dealer stated I saved about 24 hours of Labor doing this when they replace the frame.
    TheBeast and GNTundra like this.
  9. Oct 11, 2018 at 12:06 PM
    bovavet
    bovavet New Member
    2010 SR5 crewmax, 2012 SR5 double cab ,2014 limited double cab, 2016 TRD PRO,2008 FJ, 2010 FJ
    Wheel bearings?
  10. Oct 11, 2018 at 12:10 PM
    Twheatley32
    Twheatley32 New Member
    Vermont
    '23 Limited - Crewmax - JB4 Tuned
    Yea sounds about right. Good call on replacing all those. Mainly that Fuel Pump ECU. It's in a terrible spot on the frame rail. Not sure why Toyota put them there.
    Nice job saving a few grand in labor!
    Enjoy the new frame!
  11. Oct 11, 2018 at 12:21 PM
    Brijab
    07 crewmax limited
    Everything else was in good shape and since I have kept the vehicle looking like new for 12 years I argued the fact that the recall does not pay for new undercoating even though I paid for it when I bought it new and it failed. So the dealer didn't argue they did a complete undercoat on the new frame for me. I did not replace the cats as both mechanics doing the frame said they looked great and it's not worth the expense. I hope that doesn't come back and bite me
  12. Oct 11, 2018 at 12:25 PM
    Twheatley32
    Vermont
    Ehhh...With Cats you never know when they will fail. So it's a fine line to dance on.
    That's great that they undercoated it for you! Big bonus on that!!
  13. Oct 11, 2018 at 12:41 PM
    TheBeast The Beach
    man..the way they treat your roads in NY...must cost millions of dollars in repairs to people's cars
  14. Oct 11, 2018 at 12:42 PM
    Twheatley32
    Vermont
    I'm in Vermont.....You have no clue man. It's torture to these frames and anything else metal!
  15. Oct 11, 2018 at 12:44 PM
    15whtrd
    15whtrd Mr. Blonde
    I would think the cats are easy to replace with oem yourself. It’s the parts that cost the most.
  16. Oct 11, 2018 at 12:49 PM
    Twheatley32
    Vermont
    Yea they are a couple grand......too much dough for me to be under "preventative maintenance"
    15whtrd[QUOTED] likes this.
  17. Oct 13, 2018 at 9:46 AM
    Dr_Al
    Dr_Al New Member
    Al
    When I had the frame replaced on my 2000 Tundra I had them do the stuff that made sense. I did the timing belt/ water pump myself as it's not too much extra work to do, just pulling the radiator. Things like the cats, wheel bearings aren't going to make a bit of difference to a garage with a lift if there's a cab on the frame or not. One thing I would have replaced, even if it's not bad is the rubber seal for the steering shaft. I don't know how the 2nd gen does it but on my 2000 the rubber breaks down. Once it does it sounds like you have an exhaust leak.
  18. Oct 22, 2018 at 5:19 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    New member here and I see this is recent. I have a 2013 with surface rust but nothing crazy. I have 84k on my dash. Should I look into this?
  19. Oct 22, 2018 at 6:02 PM
    Twheatley32
    Vermont
    You can call but I highly doubt anything will come of it. Where is the rust?
    These Tacoma's and Tundras are getting new frames because of actual holes through the frame rail.
  20. Oct 22, 2018 at 6:06 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    Yeah I figured it's just surface rust. I was thinking if POR15 and then undercoat. It's just 200 bucks and alot if time lmfao
  21. Oct 22, 2018 at 6:07 PM
    Twheatley32
    Vermont
    Yea rust sucks....I'm in Vermont and it's nearly impossible to drive a truck year round and have it last 10 years
  22. Oct 22, 2018 at 6:08 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I'm in New Jersey and I'm waiting for the salt on the ground because it might snow lol. We get alot of snow but the stuff is so bad
  23. Oct 23, 2018 at 12:51 PM
    Twheatley32
    Vermont
    Yup! I hate it
  24. Oct 24, 2018 at 2:34 PM
    Dr_Al
    Dr_Al New Member
    Al
    Don't use POR-15. If you want to do something either use Fluid Film or LPS-3. POR-15 will convert the rust that's there but will not stop any new rust from forming while the two choices I gave you will. I tried doing my 1st gen with POR-15 before the recall started and within a year everything I did looked just the same as before. I removed the bed and used a pressure washer to remove the scale/ paint and any salt. After drying for days I took my time painting it.
  25. Oct 25, 2018 at 6:22 AM
    clemelmer29
    clemelmer29 New Member
    Fuel pump
  26. Oct 27, 2018 at 3:01 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    Fuel pump? Also I would undercoat after the POR15 but I might just do undercoat
  27. Oct 30, 2018 at 7:47 PM
    slomark
    slomark New Member
    Pgh, Pa
    2021 SR5 TRD OFF RD Crewmax
    A mechanic at my dealer told me the frame recall should also include brand new leaf springs. I somehow broke a leaf spring on my 2011. My mechanic had a free set laying around his house and put them on my truck for me, they were from a frame recall, the guy getting the frame had a lift and already had changed the OEM leafs so he told toyota to keep them. Then they ended up on
    my truck.......
    No idea how/when/why I broke a spring?
