FRAC V3 for 2020 Tundras
Discussion in 'Audio & Video' started by TundraTex, Sep 15, 2019.
  1. Sep 15, 2019 at 2:51 PM
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    EDIT UPDATE: The FRACv3 for 2020 Toyotas is available at www.FRACharness.com. Just select 2020 as your year model in the order form and you'll get the v3 harness.
    Toyota decided to change the Head Unit wiring for the 2020 Model Year. So I am designing a FRAC V3 Harness to be compatible. The design is complete and I am awaiting parts.
    So here’s where I need some help. If anyone in the DFW area has a ‘20 or will have one in the near future, and you want a FRAC Harness, I need to verify the new harness works, so it would be very inexpensive for you to acquire a FRAC Harness... I’d just ask your assistance to install it in your vehicle.
    Not sure of the time frame yet, but if someone is interested, PM me and let me know.
    Thanks!
    Lou
  2. Sep 25, 2019 at 2:27 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I have a 2020 and will want one as soon as you have them ready. I am in Los Angeles, though.
    Ely010606 likes this.
  3. Sep 25, 2019 at 3:21 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Take a road trip, you wont regret it. I have the V1, and its still the best mod I've done,
    TundraTex[OP] likes this.
  4. Sep 25, 2019 at 3:32 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    So this means, 2020 HU are not plug & play for the 2014-2019 models.
  5. Sep 26, 2019 at 10:37 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    That is correct. Hopefully it won’t change again next year with the next Gen Tundras.
  6. Oct 10, 2019 at 8:03 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Quick question on the FRAC for a 2018 SR5. Just installed it today and it seems to work fine. On the three way switch, press forward and I get front camera. Press back and I get rear camera. Put in reverse and I get rear camera.
    What is the two way switch for though? Doesn’t seem to do anything and everything works just fine wo it.
  7. Oct 11, 2019 at 2:15 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    It is for Navigation entry and other things you normally can't do when moving.
  8. Oct 11, 2019 at 5:06 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I get this question a lot. The 1/0 (on-off) switch is for the VIM function. It controls the Vehicle In Motion function which is separate from the camera function. See the text from the FRAC Installation manual below:
    VIM OPERATION NOTES
    The FRAC VIM switch should be left in the “On” or “1” position for normal operation. The VIM Switch Enables all Head Unit Function at any time. It does not affect the Camera Operations. If your passenger wishes to enable Nav functions while in motion, turning the VIM switch off to the “0” position will do this. When the VIM switch is off, the vehicle icon on the GPS moving map display may stop moving or move erratically. This is normal if VIM is off while moving. Once the desired Nav entries are made and the VIM switch is returned to the ”on” position, the GPS should start updating the position icon within approximately 10 seconds.
  9. Oct 11, 2019 at 5:11 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Just so I'm understanding this one, this isn't the harness to plug a 2020 HU into my 2019 truck right? This is the 2020's frac that lets them use front and rear camera and the nav input.
  10. Oct 11, 2019 at 6:02 PM
    Makoy339
    Super White TRD
    TRD parts
    Thats is correct.
    This is a FRAC harness for 2020 owners that would like to add front facing cameras on their Tundra.
    Jpneely[QUOTED] likes this.
  11. Oct 13, 2019 at 5:25 PM
    DividedSky
    Jeff
    Ahhhhh... makes perfect sense now. Thanks.
  12. Jan 14, 2020 at 8:41 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Can’t wait to get one for my 2020 Platinum!...want to add a front facing camera asap...I don’t live in Texas but would be happy to be a “guinea pig” if needed...thanks for making these for us!
  13. Aug 7, 2020 at 5:28 PM
    jaysbeaker
    jaysbeaker New Member
    2020 Smoked Mesquite Platinum
    Drivers side grab bar
    Any updates to this?
  14. Aug 8, 2020 at 4:09 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. @jaysbeaker, the V3 (2020) FRAC Harness is in production and is available at www.FRACharness.com. Just select 2020 as the year model in your order form and you'll get the V3.
