Fox Suspension feedback
Discussion in 'Suspension' started by SeanO86, May 1, 2018.
  1. May 1, 2018 at 7:43 AM
    SeanO86
    SeanO86 [OP] Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    Hello,
    I'm considering upgrading the suspension on my 2018 SR5 TRD Off-Road pkg and would really like to level the front 2 inches for some light to medium offroading (no rock crawling) here in CO , so I'm thinking of getting the Fox 2.5 Factory Series Coilover. I dont think I'll need the Fox 2.5 Factory Series Coilover w/ Reservoir, but I have a couple of questions I need some help with...
    I'm thinking of buying the parts through my shop as they have virtually the same pricing as online...just wanted to give you a links to show everyone which ones I'm talking about:
    https://www.realtruck.com/fox-25-factory-series-coilover-shocks/R184035P2018Y610MA.html
    https://www.realtruck.com/fox-25-factory-series-coilover-reservoir-shocks/R186186P2018Y610MA.html
    1) I noticed that the Fox 2.5 Factory Series Coilover (non reservoir) doesn't have any recommendation to upgrade the upper control arm...maybe I'm mistaken on this. I did notice that the Fox 2.5 Factory Series Coilover w/ Reservoir does require the new upper control arms. I'm a little confused here as the coil sizes are the same 2.5 inches, so do I need an upper control arm for the non reservoir?
    2) If I get the upper control arms it adds another $800 or so (parts, labor, taxes), but if I don't get the new upper control arm with the 2.5 non- res am I at risk of screwing up / over stressing the existing upper control arms? I'm trying to avoid spending another $1k, but at the same time I'm trying to do this the right way and I'm by no means an expert at this kind of stuff.
    3) Dealership told me the be VERY CAREFUL when doing my own suspension as it screws up the trucks front safety sensors and that doing anything around 2inches or more severely jeopardizes the system...and that when dealers lift trucks in house they require the person purchasing the vehicle to waive the sensor liability since they tinkered with the calibration. I have yet to hear this feedback anywhere and have seen plenty of you all here lift your 2018s 2-3 inches without any problems. am I in the clear with at 2 inch lift in regards to the sensors? I dont trust that dude at the dealership.
    Jsena likes this.
  2. May 1, 2018 at 7:50 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I’m no pro, but 2 inches of lift.. I’ve never heard anyone say that they have had a sensor issue... going to fox CO’s, I’m sure you can use about any aftermarket UCA.
  3. May 1, 2018 at 7:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Sean. I have heard several complaints about problems with the "safety sense" and lifted trucks.
    At 2" you don't really need UCAs one reason you need them for the Resis might be that you need more room for the hose to clear.
    Don't trust that dude at the dealership
    joonbug, Jsena and GodlessPro like this.
  4. May 1, 2018 at 8:53 AM
    SeanO86
    sorry for the ignorance here. you mean 2" lift right? not 2" coil...cause the Fox 2.5 means that the coil size is 2.5" but the lift is 2"... correct me if I'm wrong as I'm new to all this stuff
    Jsena likes this.
  5. May 1, 2018 at 8:59 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If I remember correctly, the reason they tell you the Resi shocks need aftermarket UCA’s is due to them being extended travel, so new control arms help you utilize the extra travel. Not real familiar with Fox suspension, paging @xtyfighterx
    T-Rex266, 831Tun and Jsena like this.
  6. May 1, 2018 at 9:11 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    2.5" means the shock body OD is 2.5" in diameter. Nothing to do with the coil size.
  7. May 1, 2018 at 9:54 AM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    I just put my lift on my 2018, it added 2" in the front, no lift in the rear. No issues with safety sense, I was careful with the sensor wires that run along the UCAs, took the brackets off so not to stretch the wires or stress them. King OEM resi's don't require new UCAs unless you have them set the shocks up as extended travel, then you need new UCAs to accommodate the extra travel. Not sure if Fox is similar in that regard.
    Jsena likes this.
  8. May 1, 2018 at 10:09 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, 2" of lift. @zcarpenter92 mentioned extended length C/Os. Not sure but I think you can order either OEM or extended in the 2.5?
    GodlessPro and Jsena like this.
  9. May 1, 2018 at 10:39 AM
    Exactly this. I dont have any first hand experience with Fox, but I've seen some complaints of leaks.
    SeanO86[OP] and Jsena like this.
  10. May 1, 2018 at 10:51 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I think that’s with every company. I’ve heard a lot of issues with all brands..
    I think Joon just had an issue with his Icon 3.0 bustin ¯\_(ツ)_/¯ I think every brand that’s been mentioned is around for a reason.. they’re all great products. But sometimes you’re goijg to have a defective product.. what separates the companies is the customer service you receive when a problem does occur.. how they take care of the issue or leave you hanging..
    monaco730, SeanO86[OP] and 831Tun like this.
  11. May 1, 2018 at 10:52 AM
    Si.
    Jsena likes this.
  12. May 1, 2018 at 11:02 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Have been running FOX for 6years on previous builds and have been very happy. If an issue popped up they would take care of it. Having experiences with Billstein, KING, Icon, and FOX (including breaking multiple billstein) I definitely prefer FOX for ride and build quality.
    The reason you're seeing one option require an Upper Control Arm is because thats the Extended Travel model. With the Extended Travel you get a little bit more droop than factory and this causes the OEM UCA to contact the coilover.
    Here are some part numbers that you can use to make sure you're getting the right shock :)
    IFP (no external reservoir)
    2.5 Factory Series Coil-Over IFP - (0-2" Lift) - 883-02-021
    Remote Reservoir
    2.5 Factory Series Coil-Over Reservoir - (0-2" Lift) - 880-02-367
    2.5 Factory Series Extended Travel Coil-Over Reservoir (Requires Upper Control Arm) - (0-3" Lift) - 880-02-947
    DSC Reservoir (Allows High and Low Speed compression adjustment)
    2.5 Factory Series Coil-Over Reservoir - DSC Adjuster - (0-2" Lift) - 880-06-367
    2.5 Factory Series Extended Travel Coil-Over Reservoir - DSC Adjuster (Requires Upper Control Arm) - (0-3" Lift) - 880-06-947
    COTundra23, T-Rex266 and Jsena like this.
  13. May 1, 2018 at 6:54 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’m running stock control arms with the extended travel resi 2.5 shocks no problem. About 3in up front I’d say. The aftermarket UCA will let your shocks perform to the fullest but if you aren’t jumping it and stuff or doing. Crazy rocky tons of flexing terrain skip out on them unless you can’t align it then that’s different. You will be fine on stock arms
    Jsena likes this.
  14. May 1, 2018 at 7:34 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    May I suggest that you watch this video.
    https://www.youtube.com/watch?v=-MsKf1lIYI0&t=2837s
    I think in the end, you should buy a setup that the shop will spec the shocks to your spring rate, use of your truck, and leaf spring setup (if buying rear shocks). Plus you may get a better price buying UCA's at a different place than Fox. They don't have to be Fox UCA's. As you said, do it right the first time.
