Fox Pro Suspension Install
Discussion in 'Suspension' started by kilotango29, Sep 8, 2021.
  1. Sep 8, 2021 at 12:41 PM
    kilotango29
    kilotango29 [OP] New Member
    Kevin
    2020 4x4 TRD Sport
    Hey guys, looking for some info from the fellas who have upgraded to PRO suspension on their trucks or anyone who knows how the Pro suspension is set up. Did y’all move existing bushings and cups from the OEM rear shocks over to the new PRO rears? Same order/orientation etc? Getting my game plan together for my swap. Thanks!
  2. Sep 8, 2021 at 12:55 PM
    15whtrd
    15whtrd Mr. Blonde
    Here are the instructions for the Bilstein pro suspension. I know it’s not the same manufacturer but it’s the same process and same results.
    https://www.dropbox.com/s/sxjguie9rkx4dti/PTR13-34140inst.pdf?dl=0
    it’s pretty straightforward. Swap your new coil overs in, use nothing but the hardware from the old coil overs. Same thing for the rear shocks.
    Mediumrarepls and BTBAKER like this.
  3. Sep 8, 2021 at 2:19 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    My Fox 2.5 came with own cups, bushings, nuts. Only reused the lower mounting bolt.
    15whtrd likes this.
  4. Sep 8, 2021 at 2:57 PM
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    I just installed the bilstein pro suspension on my truck. The only thing i had to modify, that isn't already mentioned, is to bend the ends of my skid plate. My plate on the trd offroad is much wider that the trd plate. The metal is really soft. I just used channel locks to bend it. My tires rubbed at full turn. 33" tires
  5. Sep 8, 2021 at 4:49 PM
    kilotango29
    Kevin
    2020 4x4 TRD Sport
    Thanks a ton for the feedback fellas! I have read through the install instructions for the pro Bilstein suspension but just wasn’t sure if the cup and bushing orientation was the same. Just trying to be prepared or have parts on hand if I needed em. I’ve got a set of 285/75/18 ready to go on so thanks on the tips about the skid plate! I’ll post up some pics after then install.
  6. Sep 9, 2021 at 10:42 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Be sure to check the ABS sensor wires at full droop of the suspension. Mine seemed kind of tight and needed some adjustment.
  7. Sep 9, 2021 at 6:20 PM
    kilotango29
    Kevin
    2020 4x4 TRD Sport
    I was able to get mine from Sparks a little while back. I think there were some folks that had issues ordering from them, but mine arrived in good shape and pretty fast.
