Fox Coil Over 2.5 with reservoirs ISSUE
Discussion in 'Suspension' started by benw, Jan 9, 2019.
  1. Jan 9, 2019 at 1:02 PM
    benw
    benw [OP] New Member
    Hey Everyone, new to the Forum. Just sold my 2007 and bought a 2018. It came with a Fox Coil Over 2.5 suspension but something isnt right. One side is dialed all the way down and the other side is adjusted up. But the truck is sitting well above stock height. I went into 4 wheel parts here in SLC and they are dumb founded. We called FOX and verified its all the right equipment. Seeing if anyone here has any suggestions before I start replacing stuff. The front is noticeably higher than the back.
  2. Jan 9, 2019 at 1:11 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You mean left to right are adjusted differently?
  3. Jan 9, 2019 at 1:20 PM
    benw
    Yes. The passenger side is all the way down, meaning zero lift and the driver side as shown on the pics is adjusted higher. But the truck is obviously sitting higher than the stock height which is the first weird thing because the passenger shock is adjusted with no lift on it so in theory that side should be at stock height which it is not and the driver side should be higher which it isnt
  4. Jan 9, 2019 at 1:24 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Without knowing what model fox you have I would be curious what springs are on there. Depending on spring rate and length, adjusted to fully relaxed doesn't mean stock height.
    For example, my Foxs all the way relaxed put my truck at almost 3" over stock.
    equin, 805ebr and joonbug like this.
  5. Jan 9, 2019 at 1:27 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The shocks probably have built in lift to them. Most likely about 2". Even adjusted all the way down, it should still give about 2" of lift. Adjusting them higher will probably give you +3". And left and right being different is from adjusting for the "lean". Completely normal.
    831Tun, Marty McFly, T-Rex266 and 3 others like this.
  6. Jan 9, 2019 at 1:29 PM
    benw
    The model number from the original invoice from the shop that did it is the following:
    FOX880-02-947 for the coil overs
    TOT87500 Is the Control Arm
    The place that installed everything was JBM Motoring in Orange, CA. Called them and sent pics, they are no help.
  7. Jan 9, 2019 at 1:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Are they adjustable? If so, just crank them to desired height.
    If not, maybe one is busted?
  8. Jan 9, 2019 at 1:49 PM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    I don't know for sure about Fox, but my Kings are adjusted almost all the way down and I am still at about +2" over stock height. 0 preload does not equal 0 lift.
  9. Jan 9, 2019 at 1:54 PM
    TheBeast The Beach
    on my Kings coilovers I have 3/4 to 1" more preload on driver than passenger. passenger is stock height from Kings which gives me 2"+ lift already.
    also JBM has a shop and they are pretty good. go see them. difficult to troubleshoot on the phone.
  10. Jan 9, 2019 at 1:54 PM
    TheBeast The Beach
    also check if any spacers on top of coilovers maybe
  11. Jan 9, 2019 at 2:18 PM
    benw
    No spacers. I hate the front being higher than the rear but don't want to take the rear any higher. Any suggestions on swapping this set up out for just a leveling kit or something that is not as high.
  12. Jan 9, 2019 at 2:19 PM
    TheBeast The Beach
    you could add shackles to the rear. that should even it out
    joonbug likes this.
  13. Jan 9, 2019 at 2:33 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    pics of the coilovers please
    Also please include a pic of the part number on the coils
    Watt maker and ColoradoTJ like this.
  14. Jan 9, 2019 at 2:35 PM
    Usually, with fixing the "tundra lean" the drivers side has more preload (or cranked down more). So you are opposite of everyone else.
    Unfortunately, it is not uncommon to accidentally get wrong springs. Hell, one time I ordered 14" Kings and received 12" Kings with 14" primary/secondary springs. Obviously this didn't work out well.
    So you should have some numbers on the springs. Take a pic of both sides. If they match, then we have something else going on.
    Watt maker and pickeledpigsfeet like this.
  15. Jan 9, 2019 at 2:46 PM
    benw
    039-26-105 /B is the cose on that coil in the pictures
  16. Jan 9, 2019 at 2:50 PM
    benw
    Dont know if these pics came through originally
  17. Jan 9, 2019 at 3:04 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    You are right there is definitely something wrong. The collars are far enough apart that you should have a sigificant lean too
    It is possible that someone try to adjust them and didnt get the pinch bolt tight enough and the collar jumped the threads, but you should have a bad lean if that was the case.
    The cranked down side is what I would expect to see on a 2.5 lift.
  18. Jan 9, 2019 at 3:06 PM
    pickeledpigsfeet
    Kings & Icons
    is that same part number on both springs? I have seen cracked fox springs and someone might have replaced one side with a 14” heavier spring.
  19. Jan 9, 2019 at 3:11 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Side note
    Post 16, 2nd pic
    ...might want to tighten that lock nut for the tie rod
  20. Jan 9, 2019 at 3:17 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Agreed....we call it the Carolina lean around here. Mine is doing it a tad....not as bad as yours but it still bothers me. I’m adding another .5” via CB +3 shackle to address mine. You may consider the same and/or lowering the front a bit to level.
  21. Jan 9, 2019 at 3:35 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    Have you measured the height from floor to fender on both sides? Curious to know if one side might be higher than the other, but not easily visible. Also, some difference in height adjustment between sides is normal, but the difference in your pictures looks like a lot.
  22. Jan 9, 2019 at 3:41 PM
    benw
    I have measured from fender to top of the center cap on the wheel on each side and the passenger side sits up about 1.5 higher than the driver side and the driver side is the one that is cranked down. Nothing makes sense
  23. Jan 9, 2019 at 3:46 PM
    This is making no sense. Earlier I thought your passenger side was cranked down. My mistake.
    The drivers side sure is cranked down a lot for the Tundra lean issue.
    Just to verify again, the spring part numbers are the same right?
  24. Jan 9, 2019 at 3:49 PM
    benw
    Yes part numbers are the same, its driving me crazy. Is it worth it to strip everything off and mail it to FOX.
  25. Jan 9, 2019 at 3:52 PM
    That's up to you, but something is not right.
    @Vizsla , any input to this issue?
  26. Jan 9, 2019 at 3:58 PM
    SoCalTundy
    I can tell on the pictures that the fender gap is bigger on the passenger side, yet that's the side with no lift on the adjustment of the shock. Really strange. I would start measuring anything you can; length of the shock, distance between bottom shock mount and floor. Also look at your Control arms to see if anything is bent. TCs are some of the best, but you never know. Have you checked the alignment on it at one of your local shops?
  27. Jan 9, 2019 at 4:00 PM
    SoCalTundy
    I would check the rear suspension too and make sure it all matches up.
  28. Jan 9, 2019 at 4:16 PM
    el topu
    el topu New Member
    Northern Utah
    2019 Gray Metallic TRD off-road
    You can try cruiser outfitters in Sandy or FB page UTOR for a good shop in the SLC area
  29. Jan 9, 2019 at 4:53 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would measure from the hub to fender, not ground to fender.
    Count the number of coils on each spring, I could be wrong but it looks like one side has one less coil. Maybe its marked with the incorrect part number.
    831Tun likes this.
  30. Jan 9, 2019 at 5:05 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    It Is hard to tell by the pictures what is wrong. But the first thing I notice is that one coilover has no preload adjustment at all, both side should be close adjustment. Maby they are the wrong coilover ? I have icon coilover and almost the same amount of thread is showing on both sides
    r1-superstar likes this.
