Fox 2.5 Performance Elite w/DSC
Discussion in 'Suspension' started by pursuit2550, Feb 25, 2024.
  1. Feb 25, 2024 at 7:42 AM
    pursuit2550
    pursuit2550 [OP] New Member
    2020 Tundra SR5 Maggie 1900
    They finally came in. I always forget how beefy our CO are when they are aftermarket ones. First time owning Fox 2.5, had 2.0 on a previous tundra. Currently have 6112/5160.The rears are massive. And the best part was the price. It pays to Google everywhere you can and for discount codes.
    (edit) Forgot the price. $2960
  2. Feb 25, 2024 at 7:47 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Nothing better than getting a solid deal on nice parts! Congrats!
    pursuit2550[OP] likes this.
  3. Feb 25, 2024 at 7:34 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    i was thinking about this too let us know how it works out :thumbsup:
  4. Feb 26, 2024 at 6:11 AM
    pursuit2550
    Might be a few weeks but I will. They surely can't be worse than my 6112/5160.
  5. Feb 26, 2024 at 3:44 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    You probably already did the research. How do these compare to say the 8000 series Bilstein or kings or icons?
  6. Feb 26, 2024 at 4:17 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Glad they came in for you and were in stock. Pretty sure they share the same coils as the factory series; if that’s the case I’d look into treating them somehow. Mine are well rusted after not even 12 mo. of San Diego weather. Others I’ve seen are the same. Just something to think about
  7. Feb 26, 2024 at 4:23 PM
    pursuit2550
    S.Fla here. Had Fox 2.0 before and never had an issue. But I will keep an eye on them. Thanks
    Mater[QUOTED] likes this.
  8. Feb 26, 2024 at 4:30 PM
    pursuit2550
    I did do a lot of research, but not on the 8100 series. They were too much $$$$ for what I use the truck for. Not to mention I wanted to move away from a digressive to a progressive shock. Didn't do too much looking into Icon, from the few things I read they are good just not that popular per se. Kings, well they are Kings. Some love them some dont, same for Fox. Seems Fox and King are the top sold or talked about shocks out there. I looked in Falcon, Radflow, Dobinson, Elka, to name a few. In the end they were either digressive or were too much $$$$ for what I needed it for. Not to mention the price I got the Fox's for, couldn't pass up that deal.
    Klewwless likes this.
  9. Feb 26, 2024 at 4:34 PM
    ScenicRoute
    If $$ were no object would you still get the fox. Or better put if they were all the same price would you still get the fox?
    I gotta replace my eibachs and I don’t care what the new ones cost comparatively. If I can spend $2500 and be delighted…great. Or if it’s $4000. I just don’t want to do this for a third time.
  10. Feb 26, 2024 at 4:53 PM
    pursuit2550
    Well, if money is no issue, then the skys the limit. Everyone raves about Accutune tuned shocks and they have the same one I bought for $3700. If your 2wd, supposedly you have to change the springs out to a 600lb spring, that's another $125, plus when they tune them they replace the inside piston at that another $30. I currently have 700lb springs on my bilstiens and I figured that if I need to go down to a 600lb spring, I can do that myself. But the Fox will ride better for what I want them for over the Bilsteins, so regardless it's win for me. To me the $1000 more to get them through Accutune wasn't worth it. That's a lot of money for a tune, but money was an issue for me, in the sense that I dont need that good of a ride to justify that amount of money. But money wasn't an issue in the sense that I didn't want to spend another $1-1500 and still not be satisfied. Accutune does have other packages, but they are all with in the $3-4k. Like I almost pulled the trigger on the King package for $3090, but then if I need to drop to 600lb springs, more money and not to mention the King package requires UCA, another $600+++ depending on the UCA you get. Plus the Kings package didn't come with DSC. Once again, not worth it for what I do with the truck. Decide what your end goal is first, off-road, comfort, etc, then go from there. Read up on digressive, progressive and linear also to give you a sense of what shock is good for what.
  11. Feb 26, 2024 at 5:27 PM
    pursuit2550
    Forgot to answer part of your question. If they are all the same price would I get Fox? Hard question, they all have good and bad reviews. So with that in mind, I would choose by color or by what looks nicer.
  12. Feb 26, 2024 at 5:46 PM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Good luck with the install if DIY
  13. Feb 26, 2024 at 6:00 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    So you dont like the 6112 or is it just time for replacement due to age/mileage on them?
  14. Feb 26, 2024 at 6:12 PM
    pursuit2550
    Thanks. Cake walk though. This will be my 5th CO lift install on a tundra.
    Rakso[QUOTED] likes this.
  15. Feb 26, 2024 at 6:17 PM
    pursuit2550
    The 6112 are fine, age /milage wise, they only have around 27-28k miles on them. I installed them in mid 2021. I dont like the way they ride on the road. It a digressive shock and is meant for more off-road. I hardly go off-road. My 33" BFG KO2 E rated dont help either, so those will also be changed out soon after the CO install is done.
  16. Feb 27, 2024 at 8:22 AM
    Totmacher
    Daniel
    West TN
    Some
    Interesting. I have 6112/5160 on a 4runner and love the ride both on and off road. Totally different weight and balance than a tundra though.
  17. Feb 27, 2024 at 10:15 AM
    pursuit2550
    Ride is subjective, obviously. To me, at first, the ride was what I wanted. Stiffer, more control, way less rebound and boaty feeling, etc. Then comes my 2k road trip. That's where it all changed. Now, normally I only drive 3 miles to work and back. So, on this road trip, everything changed. What I once liked turned into a dislike. The truck lost its road comfort. You could feel every pebble on the road. I could feel every road crack, road reflector, etc. Yes, you real all that but it's just different from factory shocks. The cracks pebbles, etc feel more harsh, like the shock didn't absorb the impact. Obviously this has to do with the Bilsteins being a digressive shock, reason I went progressive. They react to smaller bumps and such better.
  18. Jun 4, 2024 at 8:55 AM
    simpyson
    simpyson New Member
    2019 Tundra DC 4x4
    @pursuit2550 how do you like these Fox 2.5 DSC? How many miles have you put on them?
  19. Jun 4, 2024 at 9:16 AM
    pursuit2550
    Compared to the Bilstein 6112/5160 combo, love them. I also put 600lb springs and now have SL 33" tires instead of the E rated BFG KO2. Rides so much smoother and takes smaller bumps way better than the 6112. I got caught up on all the hype of the 6112 and should have done more research before I bought them. I will never go back to a digressive CO, ever. Same goes for the KO2. Garbage, couldn't hold balance, noisy after like 20k, expensive and not worth it.
    simpyson[QUOTED] likes this.
  20. Jun 4, 2024 at 5:07 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    What tires did you go with?
  21. Jun 5, 2024 at 3:46 AM
    pursuit2550
    I went with General APT. Could have gone with the ATX but wanted a more road type tire I stead of AT. 275/70-18
  22. Mar 14, 2025 at 6:25 PM
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    I was conflicted between these and the factory series. Mostly just trying to decide between aluminum and steel, and the fact that the elites have a smidge extra travel. I too had a decent hook up on mine and think I paid a little under $3k for front and rear.
    I ended up going with the factory 2.5 Reservoir with DSC’s front and rear. I guess I just liked the idea of steel over aluminum but I have no reason to back it up. I also live in FL so corrosion wasn’t a concern.
    And definitely good advice on the SL tires. Anything above a load C range tire turns these trucks into a driving brick.
    Trusty Rusty likes this.
  23. Mar 24, 2025 at 8:09 AM
    LunarRckplati
    LunarRckplati New Member
    Tundra hybrid Platinum
    TRD 3 inch on 35's looking for TRD pro wheels!!
