FOX 2.5 hub to fender measurement?
Discussion in 'Suspension' started by BVK, Sep 16, 2021.
  1. Sep 16, 2021 at 4:32 PM
    BVK
    BVK [OP] New Member
    Brad
    2015 Tundra CM
    Im changing my setup and would like to know from someone that has Fox 2.5 3" coils what their hub to bottom of fender measurement is so I can compare to what I currently have. Thanks.
  2. Sep 16, 2021 at 4:36 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    They are adjustable coilovers? It’s not like Bilstein clips, so 1 extra thread turn will make a height difference.
  3. Sep 16, 2021 at 4:38 PM
    BVK
    BVK [OP] New Member
    Brad
    2015 Tundra CM
    Yes thats correct thanks, I realize there can be a varying difference in ride height, just curious where some guys have landed on the taller side.
  4. Sep 16, 2021 at 4:54 PM
    ZeRussian
    ‘11 CrewMax
    They come preset at around 3” of height from factory and the driver side set at slightly higher lift to account for sag from gas tank. There is an option to go a little lower and certainly much higher but you’ll be risking shock damage with additional lift. This is if you have unmodified 4x4. You’d be looking at 3.5-4” lift on a 2wd. And lower lift if you have aftermarket bumper and or winch.
    These will have a 700# spring, so be aware that the spring rate is stiffer than factory spring.
  5. Sep 16, 2021 at 5:03 PM
    BVK
    BVK [OP] New Member
    Brad
    2015 Tundra CM
    Right on, thanks for the info
  6. Nov 23, 2021 at 4:05 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Bump, any hub to fender measurements?
  7. Nov 24, 2021 at 9:08 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    What exactly are you trying to find out by comparing someone else's setup to yours?
  8. Nov 24, 2021 at 9:10 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I think I’m 25” up front hub to fender I can measure later to check for sure
