Fox 2.5 Front Install issue
Discussion in 'Suspension' started by lambchop, Oct 10, 2018.
  1. Oct 10, 2018 at 10:54 AM
    lambchop
    lambchop [OP] New Member
    Liam
    15' Tundra Platinum
    Fox 2.5 Suspension SPC UCA's Coachbuilder Shackles
    Hi all,
    running into an issue while installing a set of Fox coil-over IFP shocks I purchased off craigslist on my 15' Tundra. Part # 883-02-021
    The OEM bolt that attaches the shock to the LCA will not pass through the heim joint on the shock, because they are the same diameter.
    I've contacted FOX and am waiting to hear back from them regarding a potential heim joint replacement or what their best course of action is.
    I'm wondering if it's OK to get a smaller bolt that will pass through the heim joint and attach to the LCA or if that will be too dangerous as it will give potential for some play in the LCA.
    Any feedback would be much appreciated.
    Thanks!
    https://imgur.com/a/PFEDQDg
  2. Oct 10, 2018 at 11:11 AM
    Vizsla
    Vizsla 2 = 2.5
    They come with a bolt, stock doesn’t work. There are also 2 spacers per side for each bolt that you need.
    equin and TheBeast like this.
  3. Oct 10, 2018 at 11:15 AM
    lambchop
    Liam
    15' Tundra Platinum
    Ok. Thanks for the info. I figured that might be the case. I got the spacers, but not the bolts when I purchased them. Any idea what the specs are on the bolt that come with the shocks?
  4. Oct 10, 2018 at 11:23 AM
    TheBeast The Beach
    see if FOX can send them to you.
    15whtrd likes this.
  5. Oct 10, 2018 at 11:24 AM
    15whtrd
    15whtrd Mr. Blonde
    It may be better to just order the bolt from Fox. Or bring your stock bolt and either the shock or spacers with you to the hardware store. Get the proper length bolt with the proper shoulder length on it. Unsure of what grade to get. I would imagine grade 8 would be sufficient.
  6. Oct 10, 2018 at 11:25 AM
    Vizsla
    Vizsla 2 = 2.5
    Grade 8 5/8” x 8” total length bolt with grade 8 washers both sides and a nylock nut. Here are pics of mine for reference.
  7. Oct 10, 2018 at 11:27 AM
    15whtrd
    15whtrd Mr. Blonde
    Nice! That should help him with the proper spaceer placement.
  8. Oct 10, 2018 at 11:27 AM
    TheBeast The Beach
    there you go @Vizsla resident FOX expert
  9. Oct 10, 2018 at 11:32 AM
    lambchop
    Liam
    15' Tundra Platinum
    Solid! Thank you for that. Do you use the small spacer on the inside of the shock? I wasn't sure if I should only use the larger spacer on the outside as shown or to use both the small and the large for install.
    Appreciate the pictures and input.
  10. Oct 10, 2018 at 11:42 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Both should be used. Not sure on orientation but looking at the pics of the other install the short is to the inside
    15whtrd likes this.
  11. Oct 10, 2018 at 11:47 AM
    Vizsla
    Vizsla 2 = 2.5
    Big spacer on the front side, small on the back. Here are Fox directions.
    equin and 15whtrd like this.
  12. Oct 10, 2018 at 12:07 PM
    lambchop
    Liam
    15' Tundra Platinum
    Any idea on the thread size for that bolt Vizsla?
  13. Oct 10, 2018 at 12:09 PM
    15whtrd
    15whtrd Mr. Blonde
    @Vizsla
    TheBeast likes this.
  14. Oct 10, 2018 at 12:37 PM
    Vizsla
    Vizsla 2 = 2.5
    I have 1/2” of the bolt showing with 5 1/2 threads so it would be 5/8-11.
  15. Oct 10, 2018 at 1:04 PM
    Vizsla
    Vizsla 2 = 2.5
    Here is a picture of the bolt for reference. 8” is the total length of the bolt, so it would be called a 7 1/2” bolt if I’m not mistaken.
  16. Oct 11, 2018 at 3:09 PM
    lambchop
    Liam
    15' Tundra Platinum
    Thanks for all your help @Vizsla - I was able to get everything installed yesterday after jumping through some hoops, but your help definitely made it possible to get everything wrapped up.
    Thanks again!
  17. Feb 20, 2019 at 2:27 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    @Vizsla hey we’re did you go to get the bolt I’m about to order and they don’t have it with my kit. U go threw fox or something else ?
  18. Feb 20, 2019 at 5:53 PM
    hngo01
    hngo01 New Member
    nice
  19. May 18, 2019 at 7:09 AM
    Justincase76
    Justincase76 New Member
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
    @Vizsla why does the OEM bolt not work?
  20. May 18, 2019 at 7:23 AM
    Trdwillie14
    Billy
    2014 trd off road
  21. May 18, 2019 at 8:28 AM
    Trdwillie14
    Billy
    2014 trd off road
    Fox bolt
    equin and Justincase76 like this.
