Fox 2.0 rear shocks
Discussion in 'Suspension' started by Blkdmax, Mar 30, 2021.
  1. Mar 30, 2021 at 6:33 AM
    Blkdmax
    Blkdmax [OP] New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Looking at getting some fox 2.0 rear remote reservoirs. Does anyone know if you can mount the reservoirs up on the frame like you can the 2.5s and several others?
    Mostly wanting to do this for cosmetic reasons and the fact I don’t want to have them clamped down there on the shock body itself.
  2. Mar 30, 2021 at 6:57 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    It is certainly possible.
    https://www.tundras.com/threads/reservoir-mounting-bracket.40607/
    My concern would be braided line length. In the photo, you can see the reservoir is against the bump stop bracket and the inlet line is almost resting on the shock mount bracket.
    It doesn't allow much wiggle room and could put a lot of strain on the braided line.
    Scenario: Full axle droop -Axle swings forward because shackles are in the rear. Therefore shock radially moves forward putting tension on braided line.
    Mounting the reservoir on the shock body minimizes braided line stress.
    Blkdmax[OP] likes this.
  3. Mar 30, 2021 at 7:54 AM
    Blkdmax
    Tennessee
    Awesome link, I tried and never found any info on the subject. Thank you sir
  4. Mar 30, 2021 at 8:07 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    i was going to do that with mine but the reservoir "tube" isn't long enough to mount with the typical mount pieces in the typical spot.
