Fox 2.0 question
Discussion in 'Suspension' started by Wildcardtundra, May 11, 2020.
  1. May 11, 2020 at 11:21 AM
    Wildcardtundra
    Wildcardtundra [OP] New Member
    2016 Tundra Platinum AWD
    I have a 2016 tundra platinum. I plan to buy fox 2.0 coilovers with the rear shocks as well. I would like to fit decent size tires with a 17”-18” wheel. I need to know if I need to buy a spacer for the rear and new upper control arms.
    Thanks!
  2. May 11, 2020 at 11:26 AM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    The Fox 2.0 units for the front come pre-set at 2" of lift. If your under 3" of lift, generally you won't need new UCAs. Just adding the Fox's on the front will get you near level, with a possible 3/4 - 1" rake, so you may not need spacers (blocks) in the rear.
  3. May 11, 2020 at 11:29 AM
    Wildcardtundra
    So do you know what size tires I can fit with the fox 2.0
  4. May 11, 2020 at 11:47 AM
    danno266
    danno266 n00b
    You're more than likely looking at the 285/70/18 and may have slight trimming toward the front of the front fenders. I don't have any lift and run 285/65/18 with aftermarket wheel that have a different offset than stock, and I just slightly rub the front of the front inner plastic liner when reversing out of the driveway. I already pulled the little air deflectors in front of the front wheels.
  5. May 11, 2020 at 11:49 AM
    danno266
    danno266 n00b
  6. May 12, 2020 at 2:49 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
  7. May 14, 2020 at 12:34 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    i went with the fox stage 4 ultimate kit (2.5" front / 2.0" rear) with res, love the ride and that it's a fully adjustable system. really happy. to me ride feels better than oem.
    can't answer the tire question op. i'm on 20" wheels and 33's.
