Fortin Evo One (WarmCarNow)
Discussion in '2.5 Gen Tundras (2014-2021)' started by DCslick, Nov 21, 2018.
  1. Nov 21, 2018 at 1:21 PM
    DCslick
    DCslick [OP] New Member
    2015 Radiant Red Tundra TRD 4x4
    Hello,
    I just received the Evo One remote starter from WarmCarNow. His video is not up to date with his plug and play version. So can anyone tell me what the below cable is used for and where would i plug it in?
    TIA
  2. Nov 21, 2018 at 1:33 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Just plug it into the module and zip tie it to all the other wires. It is for your hood but the functionality is not enabled; therefore, you do not need to mount it anywhere.
    Sorry ... I stand corrected below from @TRD15559 . I thought it was the hood pin trigger.
    DCslick[OP] likes this.
  3. Nov 21, 2018 at 5:02 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    It's the valet switch to disable the remote starter when. The truck is brought in for service. I installed the same product on my Tundra last week and just left it out.
    G10dra, lewi3069 and DCslick[OP] like this.
  4. Nov 21, 2018 at 5:49 PM
    DCslick
    Thanks for the replies. Where do you all have it installed or hanging out?
    Bigdaddy,
    Is there anything I should be aware of for the install? Was it easy? Did you have to remove the air bag or were you able to connect the cable with out removing the bag?
    L_S_SHOE likes this.
  5. Nov 21, 2018 at 6:09 PM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    I removed the airbag, it wasn't necassary but opened things up to work. If I had to do another like my truck I wouldn't now that I know exactly where everything is. Using the T harness it's an easy install. The hardest part is removing the trim. I had to solder 2 wires to TPMS wire so that I could unlock the truck with the remote once it's running. On a 2015 I think the wore you need for that is on the passenger side and called "keysense"?
    The only issue I had was after the install the alarm would go off Everytime I remote started the truck. There is an orange wire in the accessory bundle that needs to be connected to the BCM plug. That's the alarm disable wire. I connected it to the appropriate wire in the T harness to avoid having to tap any more factory wires than necassary. Once triggered, the truck is supposed to unlock before starting and lock itself a couple seconds after starting. Unlocking is how it disables the alarm.
  6. Nov 21, 2018 at 6:32 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    I installed the Warmcarnow on my 2016. Its a very easy install. You don't have to disconnect the driver airbag. I just left it sitting leaning on the side. The hardest part was pulling the trim apart. There is no soldering since the t harness on the passenger side takes care of that. You just need to positap into one wire like the directions. Super easy.
  7. Nov 21, 2018 at 8:31 PM
    DCslick
    Hi Tinman,
    In my instructions I do not see where i need to positap into the wire. Am I missing something? This kit looks to be a true plug and play kit. Also can anyone explain to me why cutting the yellow wire for automatic transmissions? I am just curious how it all works.
    Thanks!
  8. Nov 21, 2018 at 9:13 PM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    The dotted line coming from pin A19 on the unit. I was mistaken about the keysense wire being on the passenger side on the G key trucks. It appears that the wire that needs to be tapped is on the driver's side. This is only if you have a factory alarm.
    My truck required connecting 2 seperate wires from the unit to the TPMS wire, soldering is my electrical connection of choice in that situation but for a wire that requires only a tap such as the keysense connection, I would use a positap or t tap.
    I don't know the reasoning behind the yellow wire needing to be cut for auto transmission, my wire was already cut when I got the unit. Probably a safety feature for the manual transmission vehicles.
  9. Nov 21, 2018 at 9:15 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    I believe the posi tap is for factory alarm .do you have one?
    Yes you do have to cut that yellow wire for automatic transmission. I'm not sure why but it is required. I see your tundra is 2015 and mine was 2016 so I am not sure of the difference. You can always text him with the number provided. He is very helpful.
    DCslick[QUOTED][OP] likes this.
  10. Nov 22, 2018 at 9:09 PM
    DCslick
    Thank you much I glad you both pointed out that I need to positap the factory alarm. It looks straight forward but by any chance any videos on the process?
    Thanks again!
  11. Nov 23, 2018 at 6:44 AM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
  12. Nov 24, 2018 at 8:29 AM
    DCslick
    Thanks again! I installed it yesterday. Hardest parts was just removing the panels. Even the positap was simple.
    tinman10101 and BigdaddyII like this.
  13. Nov 24, 2018 at 9:25 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    i told you. lol
    awesome brother!
  14. Nov 24, 2018 at 9:37 AM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    Fantastic! Nothing left to do now but appreciate it when you get into a warm truck when it's wicked cold out .
  15. Nov 28, 2018 at 3:42 AM
    Adam New Member
    Did the kit come with a posi tap or do i need to Amazon one?
  16. Nov 28, 2018 at 5:44 AM
    DCslick
    It comes with one posi tap, no need to go out and get one.
  17. Mar 26, 2019 at 8:54 AM
    Whitetundra16
    Whitetundra16 New Member
    Ryan
    Saint Petersburg, FL
    2017 5.7 DC TRD Off Road 4x4
    How are you guys liking this alarm from warmcarnow? I'm about to buy one from them on ebay.
  18. Mar 26, 2019 at 2:19 PM
    Adam New Member
    I ended up not buying from them because after I ordered they were radio silent too long. Couldn't get ahold of them for a long time. When I did, the guy was a huge dick. Good luck.
    CO_Native likes this.
  19. Mar 26, 2019 at 4:09 PM
    bfd300
    bfd300 New Member
    I bought one few weeks ago on ebay, got it 2 days later. Simple install. Love it.
    Whitetundra16 and Adam like this.
  20. Mar 26, 2019 at 5:20 PM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Have been using mine for a few months now and its still going strong..
    Whitetundra16 likes this.
  21. Mar 26, 2019 at 6:43 PM
    Whitetundra16
    Ryan
    Rolling the dice on it.
  22. Mar 27, 2019 at 6:52 AM
    DCslick
    I typically use it every morning for the past few months and have had no issues.
  23. Apr 1, 2019 at 1:57 PM
    Whitetundra16
    Ryan
    Rolled the dice and came out on top. Got it in about 4 days and installed in about 45 min. For $180 I can't complain.
    bfd300 likes this.
  24. Apr 1, 2019 at 2:28 PM
    blizz86
    blizz86 New Member
    Anyone noticing any issues with cruise control since installing this?
  25. Apr 1, 2019 at 4:16 PM
    Whitetundra16
    Ryan
    I'll test later tonight and let you know.
  26. Apr 1, 2019 at 5:23 PM
    Whitetundra16
    Ryan
    Worked for me, no problem.
  27. Apr 1, 2019 at 5:44 PM
    mag326
    mag326 New Member
    2011 Tundra Crewmax Rock Warrior
    https://youtu.be/KL2pXH3IHtc 12 volt solutions video on Youtube best one I found. I purchased mine from warm car now with the fortin remotes. I Have had no problems. The Fortin remotes let you start, stop, and extend run time, also it has flashing light to let you know it's running.
  28. Aug 5, 2019 at 10:48 AM
    GlocKoMA
    GlocKoMA New Member
    2018 MGM Tundra SR5
    I got the remote start from same seller. Remote start works but it won’t lock driver door after remote start is activated. Did anyone else run into this?
    Kevin000 likes this.
  29. Sep 8, 2019 at 10:37 AM
    TheRemy
    TheRemy New Member
    Remy
    2017 silver supercrew limited 2wd
    Nope.. Just finished mine. As soon as it starts it restarts the alarm.
  30. Oct 28, 2020 at 6:48 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    looking to order this kit, anything new to be aware from yall on it?
