For those with fender flares... tires flush out or tucked in?
Discussion in 'General Tundra Discussion' started by JasonWYJ0551, May 6, 2019.
  1. May 6, 2019 at 3:18 AM
    JasonWYJ0551
    JasonWYJ0551 [OP] Not ur average Asian ;)
    Santa Barbara, CA
    2019 4x4 CM TRD Sport MGM
    Bilstein 6112/5160 BFG T/A KO2 285/60 R20 Icon Alpha 20x9 +16 GoRhino sport bar 2.0 GoRhino front & rear bumpers BlackOak LED 40" light bar Rigid light pods OEM color-matched door handles Winjet tail lights TRD CAI TRD grille
    I installed bushwacker pocket style with +16 offset wheels wrapped with 285/60 R20 BFG. I found out that the tires are still tucked inside the flares, which I'm not really pleased. Personally I prefer a more aggressive look with the tires to be even with the flares, or flush out a little bit. Want to know different opinions on this one. With flares, flush out or tucked in?
  2. May 6, 2019 at 3:25 AM
    Flush is my opinion.
    Try 1.25" wheel spacers.
    TXRailRoadBandit73 and 15whtrd like this.
  3. May 6, 2019 at 3:28 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
  4. May 6, 2019 at 3:28 AM
    JasonWYJ0551
    Santa Barbara, CA
    Also a fan of flush here. However I'm not a fan of spacers. I think I might either return the flares for a OEM non-extended style or return the wheels for a new set with less offset. If I cannot return both of them then I guess I'll just live with it...
    GNTundra likes this.
  5. May 6, 2019 at 3:30 AM
    JasonWYJ0551
    Santa Barbara, CA
    I actually love the flares tbh. Thinking return those wheels for another set with less offset
    GNTundra and xtyfighterx[QUOTED] like this.
  6. May 6, 2019 at 3:42 AM
    timsp8
    NY
    I have +25 XD wheels and bushwhacker flares. They are pretty flush. The wheels pushed my tires out more than I thought. I’d take a pic but pulled the flares off yesterday to wash out all the winter road salt and hadn’t put them back on.
  7. May 6, 2019 at 3:43 AM
    JasonWYJ0551
    Santa Barbara, CA
    What size of tires are you running bro?
  8. May 6, 2019 at 3:45 AM
    timsp8
    NY
    285/70 18 nitto ridge grapplers.
  9. May 6, 2019 at 3:45 AM
    xtyfighterx
    Ty
    North Idaho
    I think I had +18 offset at the time and really wanted some so I ordered them up stuck them on and it just lost the aggressiveness I took them off and sold them now I’m at 0 offset which I think might look ok with some flairs. If I could find a good deal on some color matched ones I might pick them up and try it again.
  10. May 6, 2019 at 3:46 AM
    JasonWYJ0551
    Santa Barbara, CA
    emmm... It's weird that I'm also running 285s and I have +16 offset but my tires are clearly tucked in.
  11. May 6, 2019 at 3:47 AM
    JasonWYJ0551
    Santa Barbara, CA
    Yeah bro. 0 offset with flares will look sick for sure! That's the combo I'm fancy right now. Fuel has some nice looking wheels with +1 offset. If I can get the current set returned I might pull the trigger
    xtyfighterx[QUOTED] likes this.
  12. May 6, 2019 at 5:05 AM
    timsp8
    NY
    Here they are with no flares if this helps any.
  13. May 6, 2019 at 5:17 AM
    JasonWYJ0551
    Santa Barbara, CA
    Mine looks similar without the flares. If the wheels are not able to return, it might take time for me to get used to the current setup. Honestly, is not that bad.
  14. May 6, 2019 at 6:16 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    All flares will rub through the paint.
    Tires that stick out past the flares will cause rock chips, and dirt.
    I value function over form.
    Your setup looks really good to me.
  15. May 6, 2019 at 7:27 AM
    Mine are RG 285/70/18's on a Fuel +1 offset with Bushwackers.
  16. May 6, 2019 at 1:00 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Mine are flush. Defeats the point of having flares IMO if your tires are sticking way out beyond them.
    realtorblake, JoshuaA and Bappa like this.
  17. May 6, 2019 at 1:10 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Looks better with a more aggressive stance. I personally do not like the look of flares much less flares with tires tucked in.
    I would look to a different wheel if you can get away without to much rubbing.
  18. May 6, 2019 at 4:00 PM
    JasonWYJ0551
    Santa Barbara, CA
    Thx for the advice bro! I started to think about wheel spacers but after read some threads about the cons of them I decided not to do it. I'll just get used to the current setup
  19. May 6, 2019 at 4:02 PM
    JasonWYJ0551
    Santa Barbara, CA
    Like your opinion! Indeed the flares serve more purposes of protecting the paints than giving the truck a badass look
    Sas[QUOTED] and Bappa like this.
  20. May 6, 2019 at 4:04 PM
    JasonWYJ0551
    Santa Barbara, CA
    I just called the dealer, and the wheels are not returnable if they are mounted. Not considering the spacers for sure. I think I'll just get used to the current setup. Tbh it's not that bad
  21. May 6, 2019 at 4:06 PM
    JasonWYJ0551
    Santa Barbara, CA
    Update: The wheels cannot be returned, and I don't want any spacer or getting another set of flares. I'll just keep this setup since it's really not that bad.
    Also, I noticed that the 2 left and 2 right tires are not equally aligned against the flares. I was told it is common for nearly all trucks. Is that the case?
    Boerseun likes this.
  22. May 6, 2019 at 4:08 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Looks good!
    JasonWYJ0551[OP] likes this.
  23. May 6, 2019 at 4:41 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    OP: I think your set-up LOOKS excellent, but it's a preference thing.
    Never had flares before: are you saying that the flares touch and rub against the body [taking those places down to bare metal beneath the flare]?
    That makes sense. I don't need any more rock chips. However, I have 275/65/20's at +18, and I don't have any problems.
  24. May 6, 2019 at 4:46 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Nitto RG 295/70R18 +18 and flush at the top. Without BW flares I was spraying the sides more and risking chips. What’s your side profile?
  25. May 6, 2019 at 4:53 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I'm getting extended flares soon to combat the road grime problem. I want them close to flush or it is wasted money. Black grime on a silver truck is not pretty!
  26. May 6, 2019 at 4:56 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I think I’m ok for aggressiveness, I’m going to black out the flare bolts though with Route66 kit.
    5113C4DD-8C9F-47BB-92C0-EB763FBFE143.jpg 83EE0B21-705F-4982-92E6-69660949055B.jpg
    If I were to do it again, I’d get the boltless ones. Maybe you can find those that are less wide so you are closer to flush instead of tucked?
  27. May 6, 2019 at 5:00 PM
    35x12.50x20 tires, 20x9 wheels +20 tires flush with fender flares, no wheel spacers
  28. May 6, 2019 at 5:06 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Here is mine with +20 offset and stock flares 275/55R 20 tires.
    They are almost flush which I like.
    JasonWYJ0551[OP] and JoshuaA like this.
  29. May 6, 2019 at 6:12 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Yes the rubber moulding will get grit under it and rub the paint. Mine were on for a year and I have lines that have rubbed through in a few places.
    I plan on getting some vinyl to cover it with and then I'll reinstall.
    TundraDude18[QUOTED] likes this.
  30. May 6, 2019 at 10:26 PM
    JasonWYJ0551
    Santa Barbara, CA
    This looks clean and nice! Personally I prefer the more aggressive look hence the pocket style lol
