For the life of me I do not understand offset! Quick rim question
Discussion in 'Wheels & Tires' started by Jwood562, Jun 8, 2019.
  1. Jun 8, 2019 at 7:49 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Hi guys, new to the forum but not new to modding vehicles.
    My 13 tundra currently sits on 18x9 method nv 305s +25 (I think) with 295/70/18 trail grapplers
    I also have 6112s up front top notch and about to install shackles in the rear.
    I currently have no rubbing with mud flaps removed.
    Now my question.
    I am looking at some used local rims. They are methods in 18x9 with 35s on them. One set is +12 and the other is +18.
    Now I have read and watched so many things in offset it is one concept my brain cannot visualize.
    I am guessing the lower (smaller positive) offset will push the rim away from the suspension and maybe poke out a little from the wheel well? Please help a offset newbie understand.
  2. Jun 8, 2019 at 7:55 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Yes, the lower positive number will push the outside of the wheel away from the vehicle. Once you get to an offset of 0, then it goes negative, the higher the - number,will make the wheel and tire stick way out.
  3. Jun 8, 2019 at 8:01 PM
    Jwood562
    2013 Tundra 4x4
    So am I safe to assume a lower positive, like the two sets I am looking at, the +12 will create more clearance for the the 35s. But they might just stick out about an 6mm more than the +18s? Which is about 1/4”?
  4. Jun 8, 2019 at 8:26 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Do you have a lift? I have a 5/3 and had to remove and/or relocate some of the factory trim with +18 offset and 35's on 18" wheels. It wasn't a big deal, but had to be done.
  5. Jun 8, 2019 at 8:29 PM
    Jwood562
    2013 Tundra 4x4
    I have a suspension lift with my bilstein 6112s in the front. Maybe a 2-3”
  6. Jun 8, 2019 at 8:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, they’ll stick out that much more in mm’s. But they won’t create more clearance. Actually the opposite. They will actually rub more. You’ll also need a CMC if you don’t have one already.
    Erichudgins likes this.
  7. Jun 8, 2019 at 8:33 PM
    Jwood562
    2013 Tundra 4x4
    Ok good to know. So if the +18 set is cheaper I might go that route.
    I am assuming you are taking about a body mount chop When you said cmc. I do lot have one yet but I am looking for a shop to do one. I’m in so cal and willing to drive for a good deal and a good job
    Inquiringone likes this.
  8. Jun 8, 2019 at 8:36 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    http://www.rimsntires.com/specspro.jsp
    Playing with this will help understand offset (I had trouble with offset also)
    change some of the settings (top of page) and see what happens.
  9. Jun 8, 2019 at 8:37 PM
    realtorblake
    It's going to be tight.
  10. Jun 8, 2019 at 8:43 PM
    Jwood562
    2013 Tundra 4x4
    I know it will be a snug fit. I want to fit 35s eventually. And finding a used set of rims with 35s already installed seems like a dream come true. Especially to test fit things. I was just seeing which offset would be the better of the two.
    So what I gather from the above posts. The +12s will push the Wheel out further than the +18s but will NOT create more tire/suspension clearance. But they Kight create more interference.
    I might go with the +18s then
  11. Jun 8, 2019 at 8:48 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    You might need both CMC & inner wheel well and metal perturbing into that area
    I did both as well as many others.o_O
    joonbug likes this.
  12. Jun 8, 2019 at 9:29 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Why are you changing wheels? Your NVs are the best offset for our trucks and in my opinion the best looking wheels around.
  13. Jun 8, 2019 at 9:37 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    This is the only way I can visualize it. 0 offset means the wheels inside mounting surface is dead center of the wheel relative to the outside edges. Positive pushes that surface toward the outside of the wheel and negative moves it back toward the inside of the wheel.
    ZappBrannigan and Vr0ck like this.
  14. Jun 9, 2019 at 8:07 PM
    Jwood562
    2013 Tundra 4x4
    Thanks for the help.
    I ended up picking up the rims today with 35s on them.
    Looking at my current tire set up
    I will definitely have to do the body chop mount as my current tire is about 1/4” to 1/2” from rubbing. I will also have to push the plastics behind the from bumper too.
    I got a great deal on the rims so I had to jump on them.
  15. Jun 9, 2019 at 9:05 PM
    easleycrawler
    Travis
    :worthless:
