Footwell lights that don't suck // 07+ Tundra - Hotshot Offroad
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by memario1214, Jan 26, 2022.
Thread Status:
Not open for further replies.
  1. Jan 26, 2022 at 1:46 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We finally have in stock a limited number of the V2 VLEDS footwell light kits for the 07+ Tundra! Limited numbers available now, but they are on hand!
    Some of you may have the older version of the VLEDS kits, but the new ones have much cleaner installs as well as much higher output on high! Fully plug-and-play and aluminum construction so you don't have to worrying about it breaking if you bump it!
    Dual Output - The new PWM dimmer module allows for two output modes depending on the scenario:
    • COURTESY MODE: The lights are at full output (200LM per side) when the door is open and fades out with the map and dome light when the door is closed.
    • NIGHT MODE: This gives you an adjustable low output light when the door is closed and the parking or headlights are switched on. This drops the output to approximately 10LM on the lowest setting. If you want it brighter simply use the included screwdriver and turn it up to your liking.
    Rear seat add-on kits are available as well!
    Colors Available: 5500k White, 6000k White, Aqua Blue, Red
    Kit Pricing is $100 for a front kit, and the rear add-on is $50
    Available HERE
  2. Jan 26, 2022 at 1:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Well I guess you're gonna be adding these to my upcoming order...
    :spending:
  3. Jan 26, 2022 at 1:59 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    TRDFerguson[QUOTED] likes this.
  4. Jan 26, 2022 at 2:02 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Jan 26, 2022 at 2:35 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nice. I might do the same.
    Sliders are on but not bottom bolts and top plates still need painting/install. 1/3 of the way through, I guess then now that I think about it:eek:
  6. Jan 26, 2022 at 3:10 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Son of a :censored:
    MadMaxCanon likes this.
  7. Jan 26, 2022 at 3:31 PM
    Mater[QUOTED] likes this.
  8. Jan 26, 2022 at 4:20 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just got mine in a couple days ago and I'll be putting them bad boys in this weekend :cheers:
    memario1214[OP] and Mater like this.
  9. Jan 26, 2022 at 4:40 PM
    memario1214
    Colton
    Missoula, MT
    PICS!
  10. Jan 26, 2022 at 6:21 PM
    I have the Vleds footwell kit. I actually have 2 full kits installed. I wouldn't do the dimmer in mine though....my windows are dark and I would see the reflections off of the windows.
  11. Jan 26, 2022 at 6:53 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Very cool! At some point I'll definitely do this. How many amps does a set pull? I imagine I could use the single add a fuse with a switch and be able to power two sets, to allow me to switch over red or white.
  12. Jan 26, 2022 at 7:01 PM
    0.5A for the front and 0.5A for the rear.
  13. Jan 26, 2022 at 7:03 PM
    Occidentalis
    North Florida
    Great, no problem then running as many sets as you can fit.
  14. Jan 26, 2022 at 7:07 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just looked at my kit and realized it didn't come with a dimmer :annoyed:
  15. Jan 26, 2022 at 7:13 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    He mentioned an included screwdriver, I'm guessing with the turn of a screw it can be adjusted up or down.
  16. Jan 26, 2022 at 7:14 PM
    Correct, but he may have the 4 piece kit which was before the dimmer came out.
  17. Jan 26, 2022 at 7:23 PM
    mgm16trdpro
    Northern NJ
    Gotcha, yeah I'm just guessing anyway. I've had the vled footwell kit for probably 5 years so I can't say I know much about the newer kits. Mine never had a dimmer option. Just a peel a d stick string of connected strips. I can tell everyone vled definitely makes quality products. Mine are still working great and they're an awesome company to deal with if ever needed.
  18. Jan 26, 2022 at 7:30 PM
    Yep...same kit that I have. Running 2 full kits currently. I have been using Vleds since 2012. :thumbsup:
  19. Jan 26, 2022 at 7:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have a 4 pc but the sticker on the side says 12-2021 so it doesn't seem like this kit's been sitting on the shelf long :p
    This was the only option I saw on their site at the time.
  20. Jan 26, 2022 at 7:35 PM
    mgm16trdpro
    Northern NJ
    You probably have the same kit as George and I. 1 strip plugs into the dim factory socket once you remove the bulb under the steering wheel near the bottom and the rest just daisy chain from there off each other.
    Tundra234 likes this.
  21. Jan 26, 2022 at 7:36 PM
  22. Jan 26, 2022 at 7:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sure sounds like it. I emailed them to see if I should've gotten a dimmer - may order it on the side
  23. Jan 26, 2022 at 7:38 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  24. Jan 26, 2022 at 7:38 PM
    The dimmer didn't come with the 4 piece kit. It comes with the front kit, and you can add the rear kit. You can add the dimmer to your kit.
  25. Jan 26, 2022 at 7:41 PM
    The dimmer is just for the option to have them on while driving mainly.
  26. Jan 27, 2022 at 8:07 AM
    memario1214
    Colton
    Missoula, MT
    Dang I didn't get notified of the chatter in here! So the dual-function versions (with the dimmer) are the newest version and are just coming live. It is the only version that Hotshot has ever offered. VLEDS is making a rolling transition from their old versions to this current one, and I believe that began after the new year. It wouldn't surprise me that a 12/21 version didn't have it! That said, they MAY allow you to add in the PWM. I also don't know what the old versions look like so they may not be compatible :notsure:
    texasrho83 likes this.
  27. Jan 27, 2022 at 9:12 AM
    The dimmer has the same 2 pin style plugs as the "old kit".
    https://www.vleds.com/accessories/footwell-lighting/toyota-footwell-kit-pwm-dimmer-kit.html
    jhardy1979 likes this.
  28. Feb 1, 2022 at 6:39 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well here is my "old" version kit
    bulldog93 and jhardy1979 like this.
  29. Feb 8, 2022 at 8:56 AM
    memario1214
    Colton
    Missoula, MT
    Everyone that ordered Tundra kits should have shipping info now. I think we got all of them out! :cheers:
  30. Feb 8, 2022 at 2:00 PM
    vipgs3
    vipgs3 New Member
    CA
    2015 Toyota Tundra 4x4
    can the dimmer be used for existing kits to have the functionality of them on while driving?
Thread Status:
