Folding covers and paint dings.
Discussion in 'Tonneau Covers, Caps and Shells' started by fleidermaus82, May 13, 2019.
  1. May 13, 2019 at 6:29 AM
    fleidermaus82
    fleidermaus82 [OP] New Member
    2019 Tundra SR5
    Recently got a BakFlip folding tonneau, so far so good except for one thing. It’s an MX 4 gen 2 I believe (CL find PO didn’t install due to getting wrong length) and at full fold against the back cab it has worn a couple of dings into the paint. First scratch is the hardest.... :(
    I contacted the manufacturer and the said there should be some foam rubber pads in the kit to prevent this. They offered to send the parts free of charge, so they’re on the way.
    I wonder if they’ll be enough, and if not does anyone have any experiences/suggestions?
  2. May 14, 2019 at 11:12 AM
    Octane957
    Octane957 New Member
    I have the same cover and I use a couple of pieces of paint protection film on the area the cover contacts the cab. It has seem to work well so far.
    Black Wolf likes this.
  3. May 16, 2019 at 6:46 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I've got hte same cover and yes, there should be two pieces of foam that are about .5" wide (front to back), .75" tall and 3" long (side to side) that install on the frame of the cover where it touches the cab. I've had mine on for 4 months and have had it folded against the cab probably 30 times hauling stuff and no paint issues.
  4. May 18, 2019 at 11:14 AM
    fleidermaus82
    2019 Tundra SR5
    Install was easy for the foam. Hat tip to Truck Hero for their support. I think the paint protect film may be a good idea all the same.
