Fog lights
Discussion in 'Lighting' started by Tundra2, Feb 12, 2019.
  1. Feb 12, 2019 at 11:25 PM
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Hey all!
    I have what might be a dumb issue, so here goes.
    I have installed fog lights in my '02 tundra which did not have them from the factory. I have installed an OEM Denso 567-0015 relay, and an OEM Toyota fog light switch. The switch, and relay work however they turn my high-beams on. Not my fog-lights.
    I have looked around the forum, but have not found anything that is helpful. I probably overlooked it, and I apologize if I have.
    If it helps to understand my predicament I have installed Led headlights that do NOT turn on the indicator light on my gauge cluster. I have wondered if that is the issue, or if there is a fuse that is a "dual use." If that is the case, any information would be greatly appreciated. I would prefer not cutting into my wiring harness if it can be helped since I've already bought everything I think I will need for a factory install.
    So what did I do wrong? I'm at a loss.
    Noah.
  2. Apr 11, 2019 at 4:36 AM
    Tundra2
    Noah
    Western Kentucky
    Never mind, I'm just dumb. Please disregard.
    Racingjohndeere55 likes this.
  3. Apr 11, 2019 at 4:40 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
  4. Apr 12, 2019 at 5:11 PM
    Tundra2
    Noah
    Western Kentucky
    I didn't realize that there was a signal back from the bulbs that engages the relay for the fog lights. Now I have ordered some load resistors that plug, and play. This should take care of my fog light issue, and I can keep my led headlights!
  5. Apr 12, 2019 at 6:13 PM
    Racingjohndeere55
    Thank you. Now I won't have to deal with the problems
    Tundra2[OP] likes this.
  6. Apr 13, 2019 at 5:20 PM
    Tundra2
    Noah
    Western Kentucky
    Hopefully this thread will help avoid other problems for more users like yourself.
  7. Apr 21, 2019 at 1:39 AM
    Tundra01yota
    Tundra01yota New Member
    Tabitha
    California
    Tundra SR5 4x4
    Led headlights, tail lights. 6 inch lift, 33in tires, icon coilovers.
    Did it work. I bought led head lights but then my fog lights wouldn't work. The fog light button now makes the high beams go on and off. I tried load resistors. But no luck it didnt change anything. So i put old light bulbs back in and now it all works correctly. But i now have leds in my fog lights and old bulbs in my head light. Id like to have leds in both. Maybe a diffrent led would work. Not sure. Im stumped.
  8. Apr 21, 2019 at 3:43 AM
    Tundra2
    Noah
    Western Kentucky
    Yeah, it worked for me. I bought some that plug in to the harness and the bulb plugs into the headlight. Needed a little bit of work once I got them to make them work though.
