Fog lights
Discussion in 'Lighting' started by NewTundra, Jun 21, 2018.
  1. Jun 21, 2018 at 5:43 AM
    NewTundra
    NewTundra [OP] New Member
    Junior
    2015 SR
    None
    So apperantly my 2015 SR is prewired for fog lights. Can i hust connect the lights to one end and pop the switch onto the other end, then find power for it and call it a day or will i need more work than that?
    With wiring
  2. Jun 21, 2018 at 8:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Technically that should work. You'll need power and a switch and find where the wires are in the cab. Would be nice to find an OEM push button fog switch, had one on my Tacoma and I liked it much better than the switch on the blinker/headlight lever, like the one in pic below.
    And if you're looking for OEM fog lights I'll have some off my 15, and I have both OEM white bulbs and some nokian yellow H16 bulbs for them. Will be available in a couple weeks if you're interested.
