Fog lights quit working - 2016 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Walker Moses, Sep 2, 2025 at 5:10 PM.
  1. Sep 2, 2025 at 5:10 PM
    Walker Moses
    Walker Moses [OP] New Member
    Tuesday
    Walker
    2016 SR5 TRD
    Hey all, the fog lights on my 2016 Tundra quit working. Still being the bulbs from the factory, I wasn’t all that surprised they went out, but a little suspicious both bulbs burned out simultaneously. I checked the fuse box, tested a new fuse, still don’t work. Took the fog lamps out and tested new bulbs, still don’t work. At this point, I’m not sure which direction to go - do yall have any pointers for me? Thanks!
  2. Sep 2, 2025 at 5:12 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Tripleconpanna likes this.
  3. Sep 2, 2025 at 5:14 PM
    Walker Moses
    Tuesday
    Walker
    2016 SR5 TRD
    Well buying new ones might be the solution. However, I have new LED bulbs that I tested, but they still don’t come on.
    Tripleconpanna and ToyoMafia like this.
  4. Sep 2, 2025 at 5:32 PM
    Are low beam headlights on when you turn the fogs on? I only ask because I have seen people in the past not realize that the headlights have to be on for the fogs to work depending on the year and trim level. There is a fog relay in the engine bay fuse box.
  5. Sep 2, 2025 at 5:49 PM
    Walker Moses
    Tuesday
    Walker
    2016 SR5 TRD
    Yeah, with the 2.5 gens, you can’t turn on the headlights without the fog lights coming on, or vice versa. But in my case, the fog lights won’t come on with the headlights on.
  6. Sep 2, 2025 at 5:54 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Check the fog lamp relay in the under hood fuse box
  7. Sep 2, 2025 at 5:57 PM
    Walker Moses
    Tuesday
    Walker
    2016 SR5 TRD
    I checked the fog fuse under the hood, and the current one was still in good shape, no blown. However, I still tested it with one of the spare fuses Toyota provides within the fuse box, and they still didn’t turn on.
  8. Sep 2, 2025 at 6:10 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Check the relay, not the fuse if the fuse has already checked out.
    The 2016 Toyota Tundra fog light relay is located in the fuse block on the right side of the engine bay, behind the battery. To access it, you will need to open the vehicle's hood and remove the cover panel of this fuse block.
    Steps to find and check the fog light relay:
    1. Open the hood: of your 2016 Toyota Tundra.
    2. Locate the fuse block: on the right side of the engine bay, behind the battery.
    3. Remove the cover panel: of the fuse block to gain access to the relays.
    4. Identify the "FOG" relay: within the fuse block. You may need to use the diagram on the fuse block lid for reference.
    5. Remove the relay: carefully, possibly using a pair of pliers.
    6. Test the relay: or replace it with a new one to see if your fog lights begin to work again.
  9. Sep 2, 2025 at 6:14 PM
    Walker Moses
    Tuesday
    Walker
    2016 SR5 TRD
    Ah I see what you’re saying. Where would that be located at?
  10. Sep 2, 2025 at 6:35 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    This is inaccurate....
    You can have headlights on w/o fogs.
    As others have said, check your relay under the hood, and just confirming you have the fog light switch turned on (inner part of the turn signal stalk)...
  11. Sep 2, 2025 at 6:37 PM
    Tripleconpanna
    Fogs have a fuse AND a relay; two different things... both under the hood.
  12. Sep 2, 2025 at 6:38 PM
    Tripleconpanna
    Check your owner's manual...
  13. Sep 2, 2025 at 7:18 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This video shows where you can find the relay and also gives you deets on the anytime fog light mod. I have a 2016 and, yes the mod works.
  14. Sep 3, 2025 at 5:44 AM
    Walker Moses
    Tuesday
    Walker
    2016 SR5 TRD
    Awesome y’all, thanks for the pointers. I’ll check that out today. I was unaware the relays and fuses were two separate things.
