Fog lights on a base with no original lights
Discussion in 'Lighting' started by Mattrobb81, Nov 19, 2020.
  1. Nov 19, 2020 at 3:33 PM
    Mattrobb81
    Mattrobb81 [OP] New Member
    Matthew
    13 tundra base x cab long box
    Hi I’ve got a 2013 tundra base didn’t come with factory fog lights but I bought a. Set corse they’re wrong only fit metal bumpers and also wondering what wires under the dash I need to hook them up
    My pickup has the wire ties back under the bumper for the fog lights but my question is where do I find the wire in the dash side to hook them up
    I found a kit with bezel and light
    But like better one anyone find kit less than 120$ quality?
  2. Nov 20, 2020 at 4:50 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Try this. Maybe it would help.
  3. Nov 20, 2020 at 3:25 PM
    Mongoose75
    Mongoose75 New Member
    Radel
    2003 Tundra v6
    none
    I have the same question difficulty installing 2013 Tundra, V6, double cab. I bought and installed a relay for the the fuse box, fuse is in the fuse box, and followed the instructions via youtube. connect to light blue wire in harness under dash, and second to connection to green wire in module to the left of the first wire, and ground wire. connected switch, but no power (Hollander fog light). the lights were a gift and came with no installation instructions and no dedicated wed site. There is a separate harness wiring but it appeared to be for a non prewired setup. Mine has the connectors at the light location, a relay slot in the fuse box and a fuse. Do I still need to direct connect to the battery and use their light connectors or am I tapping into the wrong wire?
