Fog Lights Not Working... Help?
Discussion in 'Lighting' started by 650h1, Dec 7, 2017.
  1. Dec 7, 2017 at 4:35 PM
    650h1
    650h1 [OP] New Member
    2013 Rock Warrior C/M
    Hey guys, so I thought it would be a good idea to try to run rigid LEDs as fogs, and began taking the truck apart. I put one rigid led in one fog light hole, shit didn't really match up, I turned the fog light switch on and it didn't work, either side. So I took it out and put it back to stock. Well... It still doesn't work. Neither side. I've checked every fuse under the hood and under the dash and they all look fine. I replaced the fog light relay. My tail lights work, parking lights work. Headlights work. Kind of getting nervous that neither fog light works. Truck is a 2013, and it has the purple/grey wire anytime fog light mod.
    Any ideas?
  2. Dec 7, 2017 at 5:11 PM
    650h1
    How do you do this? I don't have a test light... Never used one.
  3. Dec 7, 2017 at 5:20 PM
    650h1
    Any idea what fuses would affect them?
    NewImprovedRon likes this.
  4. Dec 7, 2017 at 5:34 PM
    650h1
    Yeah I replaced that one and it didn't work. I also replaced the fog relay...
  5. Dec 7, 2017 at 5:49 PM
    650h1
    I haven't tried that yet, was thinking about it. Shit is so complicated.
  6. Dec 7, 2017 at 7:10 PM
    650h1
    Got a circuit tester and tested all fuses, all appear to be working as needed. Fog lights still are not.
  7. Dec 7, 2017 at 7:57 PM
    650h1
    Disconnected the battery and reconnected it and still not working. Fuckkkkkk.
  8. Dec 7, 2017 at 7:59 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Did you reverse the wires when you plugged them into the connector plug?
    Luckydog likes this.
  9. Dec 7, 2017 at 8:17 PM
    650h1
    I'm sure I reversed the polarity when I plugged the one led in. I tried it both ways and neither way worked. So I yanked it and went back to stock.
  10. Dec 7, 2017 at 8:44 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I did the same thing when I converted too, but figured it out and had to rig my harness clips and they work great now. Maybe try again and start over.......or get some a pillar mounts from @sdhq_offroad and have you some additional lighting
  11. Dec 7, 2017 at 8:51 PM
    650h1
    Yeah the issue is that now my stock fog lights don't work at all...
  12. Dec 7, 2017 at 8:59 PM
    Eclipsed & Floating
    Voluptuous Whitey
    well, can you retrace your steps and start over? do you think you might have a bad connection?
  13. Dec 7, 2017 at 9:05 PM
    650h1
    Yeah retraced them multiple times. I literally unplugged the stock bulb, plugged in a dually, reversed polarity, plugged it in again, said fuck it, and plugged stock back in. Now nothing works.
  14. Dec 7, 2017 at 9:10 PM
    Eclipsed & Floating
    Voluptuous Whitey
    damnit
  15. Dec 7, 2017 at 9:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Well thats not good.
    650h1[OP] likes this.
  16. Dec 7, 2017 at 9:15 PM
    csuviper
    Broomfield, CO
    Fuse, plug or bulb. About all that would be affected when changing it out and back to stock.
  17. Dec 7, 2017 at 9:16 PM
    650h1
    Well the ECM controls power and ground so.... That would be awesome to have fried.
  18. Dec 7, 2017 at 9:18 PM
    csuviper
    Broomfield, CO
    If ECM was fried you would have more issues than just the fog lights.
    ColoradoTJ likes this.
  19. Dec 7, 2017 at 9:22 PM
    650h1
    Makes sense. But I've replaced everything that could have blown. The bulb didn't blow if it wasn't plugged in. I replaced the relay, checked all fuses. Kind of lost and frustrated now.
  20. Dec 7, 2017 at 9:27 PM
    csuviper
    Broomfield, CO
    check the voltage in different areas using a multimeter. See if you have power or where the power stops.
    I have two from Harbor freight. Work fine for the task. They were both a free item that they give away all the time. [​IMG]
  21. Dec 7, 2017 at 9:35 PM
    650h1
    Don't have one but I do have a circuit tester now, that will at least tell me I have power in the plug right?
  22. Dec 7, 2017 at 9:36 PM
    650h1
    Is there a way to make the lights come on without the switch? Like is it possible the switch is broken?
  23. Dec 8, 2017 at 6:53 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Did you try reverting the anytime fog mod back to stock? Some people have issues.
  24. Dec 8, 2017 at 7:05 AM
    650h1
    Checked plug, doesn't appear to be power going to it. There is power at the relay socket in the fuse box. What now?
  25. Dec 8, 2017 at 7:09 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    Not be be insulting, but have you tried them without your headlights being on HI-beam/bright lights?
    BlueBottle and 650h1[OP] like this.
  26. Dec 8, 2017 at 7:15 AM
    650h1
    Haha yes. This is day 2, I've pretty much tried everything.
  27. Dec 8, 2017 at 7:16 AM
    650h1
    Haven't done this yet. Don't really want to pull the dash back apart but...
  28. Dec 8, 2017 at 7:17 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    Man- I hate problems like this! Probably something pretty simple, we are just overlooking it.
  29. Dec 8, 2017 at 7:21 AM
    650h1
    I know, I'm ready to roll the truck off a cliff.
  30. Dec 8, 2017 at 7:25 AM
    I would try reverting the wires back. FWIW, I can’t think of a time I’ve driven with my fogs on. Granted, they’re stock and my headlights are HID.
