Fog lights not working after installing LED headlamps
Discussion in 'Lighting' started by DickeySeamus, Dec 8, 2016.
  1. Dec 8, 2016 at 11:10 AM
    DickeySeamus
    DickeySeamus [OP] New Member
    2003 Tundra Limited
    Stock, LED headlights, Dual 7 inch HID lights on Front
    Hey All,
    I own a 03 Limited, just installed some LED headlamps and now my fog lights won't work. I understand with the standard halogens the fogs would turn off when the high beams turned on. Now I turn my fogs on and the high beams come on. Ideas on how to fix this while keeping fogs and LED's? I'll also get some pics of my truck as soon as I get these fixed.
    Thanks for the help!
    LuckyLainey likes this.
  2. Dec 8, 2016 at 11:40 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
    Not sure about your question, but someone will chime in that knows their way around lights!
    Bob and Black Wolf like this.
  3. Dec 8, 2016 at 2:56 PM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    What did the LED kit consist of? Just bulbs or was there additional power and ground you had to connect? If it's the latter make sure you don't have a bad connection somewhere. Otherwise, I'm not sure.
  4. Dec 8, 2016 at 4:27 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
  5. Dec 8, 2016 at 5:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome.
  6. Dec 8, 2016 at 7:11 PM
    DickeySeamus
    2003 Tundra Limited
    It's basically just the bulbs and they plug into the original headlight plug. The kit said nothing about a ground. Also the only thing they may have recommended was a cancellation relay for newer vehicles that have led turn signals. Pretty much it Thanks though!
  7. Dec 8, 2016 at 8:00 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I had an 05 tundra access cab and when I installed hids my fogs stopped working. I looked all over the internet on how to fix it. What I found was I needed to do so the fog light mod where I needed to make the fogs and headlights function independently Basically hids draw less power than halogen bulbs and that in turn does not signal the fogs to come on.
    Not sure if LEDs draw the same power as hids.
    NewImprovedRon likes this.
  8. Dec 8, 2016 at 8:59 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Unable to help with your problem but wanted to welcome you to the forum!
    Bob likes this.
  9. Dec 9, 2016 at 12:12 PM
    DickeySeamus
    2003 Tundra Limited
    Thanks Agitated I think you're correct. How I go about fixing this I'm still at a lose. Electricity is magic in my mind, at least I'm not the only one to try this stuff. Love this community!
    Agitated1 likes this.
  10. Dec 9, 2016 at 12:30 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    here you go https://www.tundras.com/threads/diy-fog-light-mod.371/
  11. Dec 9, 2016 at 2:41 PM
    Agitated1
    Los Angeles
  12. Jan 7, 2017 at 10:22 PM
    Jwow530
    Jwow530 New Member
    Jay
    2002 Toyota Tundra TRD
    I have same problem but I add the decorder resistor but then after that my high beam won't work when the froglights are on but when I turn of the froglights the high beam works but the low beam always works and the othe problem is that the led light scatter and I don't know how to adjust it so I return them I also try two drifferent brands
  13. Feb 6, 2017 at 3:26 PM
    CalzoneCase
    CalzoneCase New Member
    I had the same problem and ordered the load resistor from SuperBrightleds. Problem Solved. Furthermore, as mentioned you only need one unit to have the fog light system operate properly.
    Shakapr likes this.
  14. Feb 6, 2017 at 4:32 PM
    Jwow530
    Jwow530 New Member
    Jay
    I try that but I bought the resistor from Amazon I try two and one same thing mybe I need the same brand as urs
  15. Feb 6, 2017 at 5:03 PM
    CalzoneCase
    I placed mine onto the drivers side LED and the Fogs work independently as they should with the fog switch next to the headlight switch. Fast fix.
    Shakapr likes this.
  16. Feb 6, 2017 at 8:06 PM
    Jwow530
    Jwow530 New Member
    Jay
    Yea I install one resistor on passager side like the other people say on the 1st gen Facebook group and even that didn't work and I even try the diver side and don't work it I have it on then I can't use my high beam no matter what I do so I decide to just return it and I order different led and samething so I got tired and return it so next I might try the hid and see
  17. Feb 10, 2017 at 7:30 AM
    vwwrench
    vwwrench New Member
    Bill
    Imperial Valley, CA
    2002 2WD Access Cab
    Adjustable Bilstien coil overs from Downey Offroad (RIP) in front to level it out, JBA Titanium headers, K&N fresh air intake system, Bilstien shocks in the rear, Air Ride load control on rear leaf springs.
    I have a little info to share on the LED lights issue. I recently bought LED headlight kits and fog light kits for my '02, I had exactly the same problem you experienced and the place I bought them XenonHID was less than helpful. They eventually offered to refund my money minus 20% for restock fee. BS, what I did was install just the LED Fog lights and bought good quality bulbs for the headlights. It works real good, you can use some of after market Blue tinted headlight bulbs to match the color of the LED fogs if you want. But the LED fog lights kick but. I ended up using the LED headlight bulbs on my '70 VW bug that I had H4 conversion headlight assemblies on and WOW what a difference.
  18. Mar 12, 2018 at 5:26 PM
    Checo CA
    Checo CA New Member
    Sergio
    Tundra 2000 SR5
    The diagram tundra 2000
  19. May 5, 2018 at 12:05 AM
    Haze134
    Haze134 New Member
    Hello all,
    I hate to ask this, but I have looked extensively and I cannot find the answer. I have a 2002 Sequoia limited which I have installed LED headlights, and now the fog lights will not illuminate. I have looked for a way forward to solve this problem, but I cannot find a write up with the correct procedure and wiring identification. I have the tools and wiring to complete the adjustment, but I am missing the knowledge on which wires to splice IOT have the fog lights work independently. I have debated installing an aftermarket switch, but I would prefer to use the factory stall if possible. Please advise.
    Dave.
  20. May 5, 2018 at 8:31 AM
    Checo CA
    Checo CA New Member
    Sergio
    Tundra 2000 SR5
    Hi Haze134,
    you need to buy a resistors for balance the loads in the circuit and can work the relay of the fog lights.
    You can find this on ebay for 15.95usd
    2x A10 EMC 9006 Headlight Kit Canbus LED Decoder Load Resistor Warning Canceller
    https://www.ebay.com/itm/2x-A10-EMC...ash=item41b3109cb3:g:1bwAAOSwLnBX2dRL&vxp=mtr
    I hope this solve your problem my friend, i was the same problema few months ago with my powerful tundra 2000
    Greeatings
    Sergio CA
  21. May 5, 2018 at 12:17 PM
    Haze134
    Haze134 New Member
    Sergio,
    Thank you. I will order those and make it happen. I appreciate the help.
    Dave.
  22. May 20, 2018 at 11:29 AM
    juand2488
    juand2488 New Member
    I have the same problem and I also bought the resistors n the fog lights still don’t turn on
  23. Jan 16, 2019 at 9:11 PM
    DJI76
    DJI76 New Member
    2006 Tundra Double Cab
    Icon 3" Stage 2 lift. 33"x12.5" on 18" K&N Cold Intake Stereo with Infinity speakers n 12" JL sub and amp Trying to install keyless with remote start.
    I have a 2006 Crew Cab.
    Just installed lEDS today same problem.
    I plan on metering out the switch tomorrow see if I can find out what's going on. But worse case scenario I'm just going to hook them up to a separate toggle switch. Then you will be able to have them on anytime. I will post what I come with
  24. Jan 27, 2019 at 1:10 PM
    catfishkarl
    catfishkarl New Member
    2001 Tundra
    I am having the same problems (fog lights not working and highs staying on when fog light switch is engaged)with my 01 Tundra after swapping to LEDs in my fog and headlights. I’ve read this thread a couple times so my question is to fix this issue do I:
    A. Put in a resistor on the headlights?
    B. Do the Fog light mod?
    Or C: do both?
    I’m trying to keep away from slicing and dicing wires as much as possible. Any and all help would be much appreciated.
  25. Jan 29, 2019 at 10:29 AM
    Surfman
    Surfman New Member
    E
    2006 Tundra
    I have solved my problem with the LED bulbs I installed. When I 1st installed them, my foglights would not work and only the high beam side of the headlights was working. I cured the problem by connecting one of the halogen bulbs in parallel with one of the LED lamps. This adds some resistance to the circuit and everything works perfectly now. I used the two outer pins on the halogen bulb and connected those to the same wires feeding the LED bulb. The center pin of the bulb is ground and is not used in this instance and because of that the halogen bulb is not turning on. You could also use a resistor in place of the bulb.
  26. Jan 31, 2019 at 6:20 PM
    catfishkarl
    2001 Tundra
  27. Feb 1, 2019 at 11:02 AM
    Surfman
    Surfman New Member
    E
    2006 Tundra
    Great to hear that! I am really glad we now have a simple solution as this was frustrating me for some time. Thank you for the source for the load resistor!
  28. Apr 16, 2019 at 1:51 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
  29. Apr 17, 2019 at 12:00 PM
    DJI76
    DJI76 New Member
    I bought a inline resistor and installed it on low beam head light wires. You just need to meter out witch wires are low beam side. I only had to hook it up to one side and my fog light started work again. If you hook it to the high beam wire they will not work.
  30. Aug 31, 2019 at 10:03 PM
    06tundrafreak
    06tundrafreak New Member
    2006 Toyota tundra
    I’m having the same issue now. But please correct me if I’m wrong. I can buy the headlight h4 load resistor and connect it between either of my headlights and my fog lights will work properly again?
